Posts: 7 |
Can I marry a 235 intake manifold to a 216 head? What about the alignment rings?
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
I have a 216 that has a 235 int & exh manifold on it. The carb mounting is different as is the exhaust pipe. It was on the car when I got it and I never had the intake off so can't answer that question. It also has a 53 235 distributor on it. Found out all the hard way when I did a tune-up and replaced the exhaust system.
Posts: 2,323 Likes: 6
Posts: 2,323 Likes: 6 |
Some of the suppliers , maybe Chevs of the 40s, sell stepped intake rings that are sized for the 216 on one side and the 235 on the other. They are usually used to mate a 216 intake on a 235.
Not a good idea but both the 235 intake and exhaust manifold manifolds must be used together.
Posts: 7 |
Thanks guys, The alignment rings seem to be the issue.
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
great to see you back gene. mike mccagh
Posts: 1,069 Likes: 9
Posts: 1,069 Likes: 9 |
I purchased the step alignment rings from a company I thought I put in my file. The address didn't work tonight . Will try to find them and hope the name is on the package in the garage.
