#412551 08/05/18 09:57 PM
Need a used 36 x 6 Tire that is good enough to move the truck around while working on it.
Dick
The 32 X 6 tire is interchangeable with the newer 6.50 X 20 tire For what you want, any 20 inch truck tire will work
My 1936 fire truck came out with 32 X 6 tires as original but at 80 plus years I didn't trust them for the miles I put on the truck. I replaced the rear tires with 7.00 X 20 and the fronts with 6.00 X 20, no issue. One note of caution, 6.00 X 20 and 6.50 X 20 will fit the narrower rims, but you must have a wider rim to accommodate 7.00 X 20 tires.
