The reason you will only find rough estimates is that the resistance is not really what matters. 6 volt coils (and 12v coils that use a resistor) usually have a primary resistance of around 1.2-1.5 ohms. It should be around that to draw enough current to magnetize the core between firings, but not so much that the points fail right away. What makes some actual difference between ignition coils is the turns ratio between the primary and the secondary part of the winding.
If the secondary is wound in slightly heavier wire, the resistance will be lower, even if the turns ratio (the part that matters) is exactly the same. For this reason, ohm-testing coils it a shaky proposition at best. You would be mainly looking for an open coil (completely dead). An ohm test could also reveal shorted turns IF you knew EXACTLY what that particular coil measured when new. Usually you don't.
I have some starting problems, car will only start with full battery charge.
The first place I would look is the battery cables.
The important thing is to get enough voltage to the coil while cranking. Battery voltage while cranking is already quite a bit less than while running with the charging system working.
6 volt Chevrolets typically pull the hot wire to power the rest of the car from the starter, so any voltage that is lost in the cables while cranking is also lost to the ignition. Any loss in the ignition switch and wiring is added to that on the way to the coil.
Two things I might do if I had this trouble:
1) While cranking, measure the voltage at the battery posts, then, while cranking, measure the voltage at the starter from the hot post to the starter case or engine block. This will reveal how bad the loss is in the battery cables and connections while cranking.
2) Turn the engine until the points are closed, and the turn the ignition switch on. Measure the voltage from the starter positive post on the starter to the starter case or engine block (again, because it will be different while not cranking). Then, measure voltage at the coil, from the positive terminal on the coil to the distributor case or engine block. This will reveal how bad the loss in in the wiring and ignition switch.
It COULD be something wrong with the coil itself, but I'll bet it isn't. A bad condenser is another thing that can cause weak spark. If you have not tried a new one, it couldn't hurt. It doesn't cost much
Good luck.
