1928 4 cyl, the exhaust manifold to exhaust pipe has apparently an asbestos rope gasket as a seal (see picture). Doing my restoration now, what have you guys been using to replace that rope seal?
Also,
how do you guys recommend refinishing the cast iron manifold?
Check at a fireplace or wood stove outlet to see if any of the modern silicon rope seals they use are the right size.
