Posts: 1,866 |
My front brake cable covers are shot and I came into a pair of good ones. Tried to take mine off and got the flexable cable disengaged but don't understand how the solid rod one comes out. The end turns on the rod but doesn't slide off so I can slip it through the cover. Thanks
Posts: 1,866 |
Thanks JYD. As I mentioned, I got as far as unhooking the flexible cable and I did tap, and I mean tap, on the pin but it didn't come out so as not to ruin anything I thought I'd ask first. Now I can take a hammer and punch and move on. But first---  Tomorrow is another day.
Posts: 327 Likes: 1
Posts: 327 Likes: 1 |
That housing is very fragile pot metal. How do you suppose I discovered that fact?
Wilson
Posts: 1 |
What axle and brakes can I use to get hydrolic brakes on my 1933 Chev. The wire wheels I intend to use have a 2 1/2 x 4 1/2 In. 5 bolt pattern?
Thanks to anyone who can give me help
wayne
First I would ask why change the brakes? The original mechanical brakes can be as effective as replacement hydraulic and don't leak fluid after a few years. If properly adjusted the mechanicals can slide all four wheels with only moderate pedal pressure. It can take more pedal pressure for hydraulics.
For most models, backing plates from '36 to '48 1/2 ton trucks and straight axle cars will bolt in place without changing the axles.
