#439547 03/12/20 12:36 AM
28cab Offline OP
Can any one help me with front end Camber adjustment on a 1928 chev
I have abad wheel shimmy wobble
thakyou
I would 1st check all the front suspension and steering joints for looseness and repair any you find. Camber isnt easily adjusted as it requires bending the axle beam, caster is adjusted by adding or removing packing pieces between the springs and the rear of the axle mounting plate.
28cab Offline OP
Thanks for your advice I have tried anding a wedge under the springs to no event ,having a guy looking at it who knows ever thing about 28 chevs
he will work it out
cheers
It is difficult for us to make sure we help you when there are duplicate posts.
