#436640 01/05/20 12:33 AM
otis3 Offline OP
will 621 bell housing work on1965 chevelle 327?and is that corect number for that car?.thanks
otis3 #436650 01/05/20 11:28 AM
From the web site of www.4speedconversions.com
The "621" Chevy Bellhousing is a 168 tooth aluminum bell with 4-5/8" center hole.
It was used on most Chevrolet Big Blocks,Small Blocks and Six cylinder engines requiring an 11" factory (Heavy Duty) clutch.
Considering the wide range of original usage, and the fact that it was in the General Motors parts catalogs until at least til July of 1987, you would think these units would be plentiful. Yet, this Clutch housing is so highly sought after, that there is now a reproduction available.
otis3 #436676 01/05/20 07:43 PM
otis3 Offline OP
thank you very much.thought the belhousing,621 was used with 11 inch cluth,on sb and bb
