Did you check with Show Cars in Minnesota? They seem to have a good selection of "correct" looking reproduction parts. The radiator I purchased from them 20 years ago for my 348 is performing perfectly
John
I have used radiators from Classic Industries, Jeg's and Summit with no issues, 3 row and 4 row, as well as a correct 409" radiator from Show Cars that had the correct sloping top.
They all looked and worked as original with no issues.
I no longer use Eckler's as I posted a honest review stating that I felt their shipping charges were inflated, especially with the "if it fits, it ships" pricing from the USPS. On several of my orders the cost they added was more than double the going rate. Very small parts that went inside an envelope. I understand that there is manpower and overhead to account for, but compared to other suppliers who have similar costs, Eckler's was over 2X comparable shipping.
Anyway, they deleted my comments and sent me note that they do not allow negative reviews. When I looked at their website again, sure enough, there was nothing but glowing remarks. This makes it impossible to see how they really perform. To me it matters, and the best way to express your concern is with your wallet, which I did.
Bobalouie
I agree Bob, I too avoid Eckler's shipping is WAY OVERPRICED, and technical support is not there AT ALL, and I am talking about a simple question that they could not answer.
I just checked the Show Cars catalog and they don't list a small block radiator.
John
thank you both for your helpful comments, bobalouie and john...I will contact eckler's and inquire about the shipping on their radiator, since they even mention on the webpage that "this item has additional shipping charges due to heavy weight or oversize dimensions"...
they quoted $52 for ground shipping plus an $11 shipping surcharge...the base shipping sounds about right, but since it ships direct from the manufacturer, the surcharge is just extra revenue for them...I may still order it from them, but I wonder why they don't choose to be more direct and just increase the item price by eleven dollars?..
If you know the manufacturer of the radiator, you may be able to contact them directly and avoid middleman upcharges...just a thought. Good luck on your project!
yes, that's possible...i haven't actually pulled the radiator to see where the pinhole leak is, but the tanks still look excellent from the outside...over the recent years, most of the old radiator shops around here have closed, leaving just the newer shops that mostly like to work on modern cars...I called one the other day in a nearby town and he said it would be anywhere from $500 - $750, if I brought the radiator in removed from the car...so I thought, well for that kind of money, I may as well get a new radiator...my guess would be that any new radiator may not be as well made as my original harrison, but the old radiator is almost sixty years old and the tanks are probably are't as good as they once were, either (I sound like toby keith)...but maybe I should try calling another shop...thanks for the suggestion...
I had looked at their site...they offer aluminum radiators that they claim will look original after painting...has anyone used one of these and found that to be the case?..and were there any issues with mounting and fit?..
finally, is the aluminum two row as effective as the brass & copper 4 row?..
the price is appealing, as it's only 2/3 the cost of the brass & copper radiators...
I would personally have a shop look at it first. It might only need the pinhole fixed, and get away with having it boiled out. If your going to replace you still are going to have to take it out regardless.
John
I drove three towns over to the last remaining old-time radiator shop that is still operating around here...unfortunately, the owner said that it's leaking from the core and can't be repaired...he also pointed out that it is a two-row (i had always assumed it was three)...was this the standard radiator for a 327/250 w/o ac?..
An old school shop should be able to install a new core in your rad. Is your rad too far gone or just too expensive to do a recore vs a replacement rad?
I have purchased OEM style radiators from Jegs for a '62 Impala, a '65 Malibu, a '62 Nova and a '64 Belair. All cooled well and fit and looked as original. My cars were drivers, not show cars, but I had no issues. For the price difference, I went with the 4 core radiators, although I was not having a cooling issue with the stock radiators. All cars were 327" motors, with approx. 360hp, 4sp and autos. I would buy one again, for what it's worth. Bobalouie
Yes, it did fit I bought a '62 Impala that originally had a 327" and was replaced with a 409". They did not change the radiator when they made the switch, so I installed the HD, correct 409" radiator. It was a direct bolt-in replacement. I also did the same thing in a '64 Belair that originally had a 6 cylinder, replacing it with a 409"...no issues, but I did use the fan shroud as the 409" fan shroud is about 1" shorter to allow for the longer water pump on the 409" versus the small block V8 or 6 cylinder motors.
i have a powerglide, so I hope that the cooler ports are in the same place for the lines...and I assume the upper and lower hose diameters and locations are the same?..
I was doing 4 speed cars, so I can't remember if you have to order the radiator for a auto or a manual. 409" cars did come with both, so I would guess you still can order the radiator with the proper fitting outlets, and them may have one radiator, and if you are using it with an auto, just plug those outlets. Yes, the hose diameters were the same. Bob
A/C 327 cars had the the same radiator as the 409 cars. The factory radiators had a three row core but, the tubes were larger, more surface area to cool with four rows then three. The core dimensions are the same, internally is the difference. I think their radiator is around $400 plus shipping. When you order ask for Bruce. they are the best vendors for these cars, mostly deal in 409's and 348's
John
Only the 300hp 327s John. 250hp 327s with A/C did not get that radiator.
Verne
Correct, my mistake for not being clearer, thanks
John
Just to be clear, The 4 row "409" radiator that Show Cars sells does have a thicker core than OEM. The edges of the tank straps have to be trimmed away where they fold around the original core. Photo is of an original. Verne
yesterday, i installed the new 409 radiator from show cars...but when i went to connect the "gm" stamped upper radiator hose today, i learned that the radiator inlet is three inches further outboard than my original 327 radiator...the lower outlet and hose are perfect...the upper hose is too short (the offset is no longer correct because of the inlet location...
i'm hoping there is a different, molded upper hose available as a fix for the problem?..
The difference is slight. The 409 is a little longer than the 327 so the outlet on the manifold is in a different place. You could "probably" make the 409 hose work.
The parts book lists the same radiator for 1963 with heavy duty radiator, high performannce 327 engine, air conditioning. 409 engine, and....Power Glide transmission.
The only difference being the '63 radiator with a Powerglide had the trans cooler lines in the bottom, where the standard trans radiator didn't have those lines (or fittings). Two different part numbers.
then in a 409, are both the radiator filler neck and the thermostat housing on the engine aligned to the centerline of the car?.. are they aligned to each other?..
the 327 and "409" radiator are the same width overall when including the mounting brackets...
the filler necks are centered in both radiators and the car...
the 327 & 409 thermostat housing outlet are centered on the engine and the car...
verne measured a 409 radiator and says the distance between filler neck and radiator inlet is 9"... this suggests that the thermostat outlet and radiator inlet are also offset 9"...
the napa auto molded upper radiator hose for 409 (without a/c) only had a 6" offset...
Here's what I do whenever I can't find the right hose. I simply take a clothes hanger or similar wire, bend it to the shape that it needs to be to connect to both outlets, and then I go to O'Reilly's or Napa and explain what I'm doing. They are great about letting me go back and find a hose that will work. I may have to cut off a slight amount from each end, but 99% of the times I have found one that fit perfectly.
but i'm trying to determine if the napa auto 409 hose that they offered me is the correct hose...everything i've learned here indicates that the correct 409 hose should have a 9" offset, but unfortunately, i don't have a 409 to measure myself to confirm if i have all my facts right...
That's not the question. A 409 with A/C is a completely different radiator. I'm telling you a 300hp 327 with A/C uses the same radiator as a 409 (without) A/C. The hoses should be the same. You said the NAPA hose for a 409 has a different measurement than you need, so I asked if NAPA has a listing for a different hose for the hi-perf 327 with A/C. It's the SAME hose, but NAPA might show it differently and maybe that is the one you need. You said they stock a hose with a 6 offset, but now you say they only offer a flexible hose, so they can't help you. Have you tried searching Google for reproduction radiator hoses? See what applications come up.
Here is what I can offer. I have a '64 Belair with the 409", 425 horse motor.
NO A/C It has the heavy duty, slanted top radiator.
I measured for you, and going from the centerline of the thermostat housing to the centerline of the radiator inlet, it is offset towards the passenger fender by 10 1/2".
Also, starting at the thermostat housing, the hose extends 6", then makes a 45 degree bend towards the passenger fender; from the center of that bend to the center of the next 45 degree bend, it is 9 1/2" long. From the center of this bend to be flush with the radiator inlet, it is 4" long.
Napa does list a molded hose, NBH 7209, that states that it is a cut to fit design. I looked at mine and I did cut one end to fit perfectly.
The original GM part number was 3780334, which you may be able to use to cross reference with Gates or Dayco.
O'Reilly list a molded, cut to fit under part number 20380.
napa lists the 327/300 with a/c as requiring the napa auto universal flexible hose...so they do not have a molded hose for that application...
i did order a molded hose from show cars for a 409, but it did not fit...it only had a 6" offset...they do not offer a 327/300 a/c hose...
there is a 327/300 a/c hose from a vendor, but they said they will not measure it...so that would be a crap shoot...the same one being offered by them on ebay...
at this point, i think i'll buy the 409 hose from napa and try it on...
