I respectfully disagree that the truck first gear is not usable. It is very usable for going slowly in parades. The truck tranny's second, third, and fourth gears are equivalent to the car's first, second, and third gears.
I recently drove Lurch (see links below) in a parade and in granny first he crawled along at walking speed. It was very pleasant to drive this way in the parade.
I would point out that using a granny gear sounds like a good idea but I wouldn't do it. If you get a hot day out and you're turning higher RPM's the engine will get hotter. I do parades too with my 31 Roadster and use a 4 bladed fan. It isn't as easy to go slow but it does run cooler. My 2 cents worth.
