"I pushed the clip off with a pick."
BJ,
The above statement means a lot ln that "off" means that the clip is now not part of the issue. So do you have the clip in your hand or did you merely rotate it?
If the clip is actually out and off then merely tap the handle with brass hammer. We don't use ball-peen hammers on the knobs on a 41. Hammers are used on 37/38s only. They were part of the unit and several different sizes were in the trunk.
The 41 had a really small ball-peen hammer. Instructions in its use merely stated it was for shaking at the missus
whenever she forgoets who is boss. That happens sometimes smf when it does, it need immediate attention. Accordingly when she starts to act up and needle you about such things as how come you don't stop and ask directions. You perpare the such annoying events by getting it out of the trunk in anticipation of its need and placing it in the middle of the fromt seat.where it will be instantly availabilie for the need occurs. It will, count on it.
If you have to bust the handle or cut it off, I have some. Not show quality but good enough for a driver. Just let me know if you need one and it will be free and postage paid by me.
Keep messing with it until you get it off even if you have to cut it off.
Best,
Charlie
BTW: Don't ac” ually hit the missus with the ball-peen. Merely threaten to. Also, don't threaten her with children on board. They will always take her side and tell e v e r y b o d y!
