[b][/b]HELP! Rebuilding a 35 EC transmission and having trouble finding a caged needle bearing that fits on the front end of the main shaft (I call it the output shaft), and into the rear of the input shaft. I have all parts to rebuild except this bearing. I ordered part number B-12 shown in the Filling Station catalog for the 35 standard, but the bearing is too small and will not fit my main shaft. Main shaft measures 0.688" (11/16") and the old bearing out of my transmission fits the shaft and inside the input shaft. Anyone know what I have or where I can look for the proper caged bearing to replace with. The outside diameter of the bearing needs to be very close to 1" I measure the bore 0.998". Any help??
