Posts: 656 Likes: 3
Posts: 656 Likes: 3 |
OOOOOOH... Did I misunderstand?
In my post above I was thinking that the starter wouldn't CRANK without the little wire hooked up.
keroppi: Does it not crank? Or, does it crank and not start?
I did not follow this thread fromte beginning but the extra wire on the starter may be left over from the polairty reversing switch that was used on 1941-early 1948 Chverolets. See polairty,reverse in the shop manual.
Posts: 191 |
I am trying to determine if the small wire at the starter is the power supply to the ignition circuit. You can check as I posted above or simply use a jumper wire and touch it from the terminal on the switch to ground momentarily. If it sparks it's a power feed for ???? in the ignition circuit. The wire most likely goes to the ammeter which would feed the ignition switch. Rather than try to explain the whole process it would help me more if I knew where the wire in question goes to . I'll look into this...
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
It's possible that the starter is 12 volt and that wire went to a ballast for starting. If it were mine I would drive it as is to get it home (if not there already) and then rewire it the way it should be. I see no reason to ground the case of the switch with a separate wire as the mounting screws will do that. It would be interesting to know where the other end of that wire attaches. You may have posted that earlier and I missed it. The instrument panel only needs ground for the panel lights . Probably time to determine what voltage the starter and generator are and go from there.
Posts: 191 |
It is at it's home for the time being.
Posts: 1,069 Likes: 9
Posts: 1,069 Likes: 9 |
Your battery is on the firewall. Mine is under the floor on the passenger side. I will try to remember to look at my 46 tomorrow afternoon. The stud on the side of the starter button should not be for the ignition. I think Gene is right about the reverse polarity switch, which most have been removed.
Posts: 191 |
I did not follow this thread fromte beginning but the extra wire on the starter may be left over from the polairty reversing switch that was used on 1941-early 1948 Chverolets. See polairty,reverse in the shop manual. I missed this earlier, thanks.
First let us determine what distributor you have. Does it have two wire terminal studs and nuts. one on each side --- or just one.
Posts: 191 |
First let us determine what distributor you have. Does it have two wire terminal studs and nuts. one on each side --- or just one. I will get that info.
Posts: 3,511 Likes: 48
Posts: 3,511 Likes: 48 |
If you take your starter to a shop for rebuilding, make sure you tell them not to paint over the info tag, of one is there.
Or, as I did with Lurch's generator, tell the shop not to paint the outside at all and leave as much crud as possible. ;-)
Alan, Can't see enough there. Wait til you get time.
Posts: 191 |
Alan, Can't see enough there. Wait til you get time. Have some info. There is definitely only 1 wire/post on the distributor.
I can't see around the bell housing without jacking the truck up. What about using a flashlight and one of those little mirrors on an expanding wand? Either that or pay the neighbor's kid to climb under the truck and read any info there. ;-) Dean
Posts: 191 |
What about using a flashlight and one of those little mirrors on an expanding wand? I hate to admit, I don't have one.
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
Hopefully JYD's suggestion is not right, the numbers you are looking for are on a small oval? The plate is riveted to the main housing on all 3 items (distributor, generator, starter) but those plates may be a little difficult to read when you do find it. Tony
Posts: 191 |
I found a number on the bottom of the starter.
ruscar just posted this pic of his starter. Maybe some clues there for the electrical hookup. Cheers, Dean ![[Linked Image from pic100.picturetrail.com]](http://pic100.picturetrail.com/VOL401/9967837/17988031/414075642.jpg)
Posts: 191 |
ruscar just posted this pic of his starter. Maybe some clues there for the electrical hookup. Cheers, Dean ![[Linked Image from pic100.picturetrail.com]](http://pic100.picturetrail.com/VOL401/9967837/17988031/414075642.jpg) Yes, there is a clue here...
Posts: 191 |
Posts: 656 Likes: 3
Most voltage regulators of this era were meant to be adjusted for voltage.
Current and cut-in voltage are often adjustable too, but those are set to book settings and are rarely adjusted.
The voltage setting can be changed and often was to better match the owner's driving habits. The change made would be small, usually 0.2V or so, and then recheck the charge level in the battery (with a hydrometer) after a week or so. Repeat if necessary.
The idea is to keep the battery fully charged, but not overcharged. Generators charge little if any at idle. Temperature is also a factor (though many regulators are temperature-compensated). A person who drives a lot at night in the city may need a higher setting, while someone in rural Arizona who only drives in the daytime may need a lower setting.
The cable going from the cut-out-switch to the front of the head appears to be inferior. That should be a healthy cable, and I would eliminate the cut-out-switch.
Posts: 1,743 Likes: 11
Posts: 1,743 Likes: 11 |
Actually in the above picture, the ground cable is bolted to the bell housing. Look just to the right, below that spring, you will see the started bolt. Check yours in that area to see if you have a threaded hole there.
Posts: 191 |
Ok, here's my new theory... First I want to say I believe this new theory is correct and I'm going to claim success.
