Posts: 4,374 Likes: 30
Posts: 4,374 Likes: 30 |
I have a Schauer Charge Master Solid State Battery Charger Model: B6612 Does anyone know anything about it ?  What about a manual or such ?? Has a 6v/12v switch @ 6 Amp Looks to be in great shape, they good chargers ?? Image 01Image 02Image 03
Posts: 1,294 |
I have one in the garage now. Had it for many years. Drove race cars for 20 years and used it weekly for them. Still works good.
Thanks guys
I will see if i can pop it open and get some pictures inside
'Yes I am engineer, and yes I love to take things apart'
Posts: 687 Likes: 3
Posts: 687 Likes: 3 |
I'm not an electrician, but how does it convert to DC? Rectifier?
From fellow on AACA a transformer and two diodes. Full wave rectifier circuit. That is a circuit breaker on the bottom next to the diode holder. Diode holder is at the end of the enameled transformer wires. which make sens looking at it
Posts: 1,894 |
The links won't open for me without a google account and I sure wish I could see them, but there should be a rectifier inside like you said. Possibly a couple large heavy duty diodes as the battery isn't picky if the voltage varies and is a bit dirty.
Simple and heavy duty is the best for these. Had to buy one for work and it's hard to find a charger that does not have a computer controller in there somewhere these days and you know what will fail first don't you...
that is strange, i updated the settings, should not need an account to look or see the linked photos....
let me know if it works
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
Tim Most power reduction units (battery chargers, plug packs and similar) are of the switch mode design but dont ask me to describe operation. It does produce a very stable voltage output at fluctuating amperage demand. Tony
