Posts: 2,566 Likes: 14
Posts: 2,566 Likes: 14 |
Was the straight axle and knee action both available in 39’ and on what models. There’s a nice 39’ business coupe being advertised as a Master Deluxe and it has a straight axle. I thought the knee action was used on the MD series but I don’t have much knowledge on these cars so I’m asking.
Thanks for this Dave, it really helps. Now another question. Was the pickup coupe available as a master deluxe or just a master 85. It sounds like it could have been both trim levels but both would have been on the master 85 chassis. Does that sound correct?
Posts: 812 Likes: 13
Posts: 812 Likes: 13 |
The 1937 and 38 Standard (straight axle) frame will interchange but have minor differences. The 1937 and 38 Deluxe (Knee action) frame will interchange but have minor differences. The 1937 - 38 Standard and Deluxe frames will not interchange. The 1939 used double A arm front suspension on JA. The JB (39 straight axle) was called "Master 85". The 1937 - 1940 passenger car straight axle are the same with 26" between bolts. The 1926 - 1954 half ton front axles will not fit the 1937 - 40 passenger cars as they have 24" between bolts. Exception: If you have a 1937 or 38 Limousine or Taxi, it comes from Chevy with an adaptor to use 3/4 ton axles. . The coupe pick is listed as Standard only (37-1271P) on Fisher ID tag. One could purchase the pickup insert from parts and make one. The Fisher tag would read (37-1271). Mine is a deluxe and the tag reads (37-1071P). Go figure?? Lou
