#40991 04/12/03 08:56 AM
I'm getting ready to do some engine work on my '67 C10 1/2 ton Chevy pickup. I would appreciate information on the color of the valve cover, block, and engine compartment. The present valve cover color that is remaining appears to be a blue gray and is similar to the color on my '34 1/2 ton, which I think is called Chevy Blue. Are the colors the same? Thanks in advance for any info. WJB
Wilwood Engineering1955-1957
#40992 04/12/03 07:00 PM
Williejoebob,
I tried before to find you info on your truck and still have had no success finding the 67 engine colors.
I did find this article that may have some good information. The link is below
67-72 trucks
Regards,
Jim M.
#40993 04/12/03 07:26 PM
Jim: Thanks a lot. I'll check out the site. WJB
