Tony,
Here is the data from my 1929-50 parts book:
Canshaft 1938-50 (with 216 engine Forge # 838733
1941-49 (with 235 engine)
1950 all comm and util (w/235) Forge #3660474
1950 All Pass With P/G Forge # 3835502
I think the above numbers would hold untio the 1954 235 but not sure.
(Got company. More later)
Charlie
OK, I'm back,
Gear (Crankshaft timing (steel)
1937-39 All use w/838436 gear only. 27 teeth 3 1/8 OD1 1/4 in ctr hole
Part #838432 Note: 838432 has one timing punch mark.
1940-50 (27 teeth 3 1/8 OD stamped "71"
Gear (Camshaft (fibre)
1937-39 All use with 838432 Gear only
1940-47 All use with 383571 gear only
1948-50 (exc two ton) use with 383571 Gear only 54 teeth part # stamped on
Part # 838436
Again I doubt this will stand up with the (54) 235 engine
Hope this helps.
Charlie
