Page 2 of 3 1 2 3
Originally Posted by Chipper
You can't damage the wiper motor with too much vacuum. Too much pressure can cause damage but vacuum is limited to the atmospheric pressure.
Thanks Chipper I pulled the top cover off and the sweeper seemed to be a little tight at the end of the stroke. I gave it a little push and it moves fine. I reassembled the motor and connected it to the vacuum side of the compressor. It works great! parking
The path of the paddle should be coated with a grease to lubricate as well as make a better vacuum seal. When the grease gets old and hard the wiper action gets weak or none at all. This is even true on a new old stock wiper moter. They have to be taken apart, old hard grease cleaned out and fresh heavy coat applied.
What do you do for the fine detail , thin gasket that seems to come apart when you take the top cover off? Are they available from some source? For me it is a real challenge to make.
The control parts are I believe under the pry off cover (tin). If the top of the motor housing with paddle etc is removed you will need to replace the gasket if destroyed. With bare clean housings if you put a thin colored grease on one housing with a thin paper between the mating half you can get a good outline for the gasket. It will take some patience and fine scissors to cut out. My motor used two identical gaskets so I folded the paper and cut both at the same time using cuticle scissors.
I pulled both covers off. The inside is liberally greased with a reddish colored grease. The only gasket is under the large cover. It is thin, however since mine is a rebuild (from Gary W.) the gasket appears to be factory made and still in good shape. The small cover has no gasket and I believe it has to allow makeup air into the wiper motor as I could not see any other opening for air to get back in.
https://photos.google.com/search/_tra_/photo/AF1QipOeEtJypIo6bTiyg7mzKbBavFKK4BYiXG1c3ekK
Photo link requires a google account
I'm not sure of the best way to post pictures anymore.
if posting from google.... ( i use google)
you have to click on the picture you want int he album to open it up
click on the share icon top right, should be the < looking one all the way to the left (Share, Edit, Info, Options)
dialog box opens up
then click on get link icon (Gray chain link)
google generates a link and shows it
click "COPY" this copies link to your clipboard
can NOT right click on it and copy image address any more with the new security !!
then paste link here using the 'Insert Link' option
I Have NOT been able to post a Google Image in a Message on these Forums due to Google linkage and formatting!!
need any help let me know
this is how the LINK should look
https://photos.app.goo.gl/80QDlaciIo5x1ThB2
Posting pics is actually much easier, once you find out how of course.
Peter pointed out the attachment Manager to me.
Just make sure that you use the Full Editor, then use the Attachment Manager in the Full Editor to post the pics
Jeff
1925 Superior K 4 Dr Sedan
1966 C10
2003 Silverado 1500 HD
Thanks JT
My file is 2.3meg. so I have to edit it.
Hey Bare Foot,
Resizing is easy. Try this:
Doing this yourself is really simple. You should have all the tools necessary to do it without having to download or purchase anything.
If you have a windows computer, you simply use the the Paint software that comes with Windows.
Locate your picture on your computer.
While hovering over the picture with your mouse, click on the right side of your mouse, or right-click.
A pop-up will come up with a list of options. Hover over the words 'Open With' with your mouse. A fly-out should appear that has an option for 'Paint'.
Select Paint
When Paint opens it will display your image.
You will see 3 tabs near the top of the page. File/Home/View. Make sure the Home tab is selected.
There are 5 sections under the Home tab: Clipboard, Image, Tools, Shapes, Colors
In the Image section you have Select, Crop, Resize and Rotate.
You click on the Resize option first.
In the pop-up you have the option of resizing by: Percentage or by Pixels, select Pixels.
The Horizontal pixel count should be reset to '100', the Vertical will change accordingly.
You can now save the image. In this case your image was resized to 100x68 pixels.
A lot of times I will have a large image that I bring in from my phone. It will be 3000 pixels by whatever. I will first resize it to 1000 horizontal pixels so that I can see the complete image. Then I will use the crop tool hone in on the part of the image that I intend to be focused on. Once you crop it it will resize the image again to the same 1000 horizontal pixels.
Play around with it. Paint is easy to use and you can find it on any PC.
Good luck. Let me know if I can help any further.
Jeff
1966 C10
Done, Thanks beer2
wow, that thing looks like it was used in a zombie movie
Jeff
1966 C10
Gaskets and rebuild kits are available from several Model A part suppliers. I prefer Snyder's as I have been buying Chevrolet parts from them for nearly 50 years. Yes there are a few parts that also fit those Fix Or Repair Daily cars.
Chipper this the correct rebuild kit for our trico wipers ?? Vacuum Wiper Repair Kit
This would be the gasket only: Trico Bowl Gaskets
Thanks for the tip on Synder's just ordered a couple of kits.
Well spent the weekend tearing down and rebuilding the wiper motor. I Took my time, broke it down and laid out all the parts as i took them apart, took pictures of most every step along the way. followed the instructions that came with my rebuild kit, even ordered an extra gasket just in case i destroyed the one in the kit !!
1929 Wiper Motor Original 01
1929 Wiper Motor Original 02
1929 Wiper Motor Original 03
1929 Wiper Motor Original 04
1929 Wiper Motor Original 05
Basic Tear Down of the MAIN components
Main Parts Spread
Original Gasket on Wiper Body Cover
Original Wiper Paddle
Tore Down the Original Wiper Paddle
Wiper Paddle Parts
after tearing everything down time to clean each part up, remove the old grease and grime.
I took my time doing this as NOT to damage any surfaces or break anything.
also the copper parts of the paddle are very thin !! and their are NO replacements.
Here is a shot of the rebuild kit
Trico Rebuild Kit
Side by side of OLD vs NEW Paddle Seal
Paddle Seals
Then time to rebuild the paddle and then the Vacuum Assembly.
I read instructions a few times, dry fir the builds, then assembled and secured.
Vacuum Body Greased Up
Paddle Greased Up
Vacuum Body Cover Greased Up
Gasket Installed
Then Assemblies the parts, installed the mechanisms that make it work.
Vacuum Wiper Rebuild 01
Vacuum Wiper Rebuild 02
Vacuum Wiper Rebuild 03
Vacuum Wiper Rebuild 04
Vacuum Wiper Rebuild 05
I ONLY had to trim one small section of the gasket, easily done with a razor blade. and realized on my model I did NOT really need the ROUND stop Sealer, but oh well.
once it was built, time to test it out... figured the best way to test a vacuum motor is with a vacuum !! but how to adapt it to the motor ??
I took my small house cordless vacuum, and then taped my plastic dollar tree turkey baster on to the end of the hose using vinyl tape (electrical tape). wanted to avoid any vacuum leaks. then the turkey baster end was a little to big for the vacuum connection, so wrapped a few turns of vinyl tape around the fitting and got a NICE SNUG fit. fired up the vacuum and NOTHING happened. short panic set in and thought the wiper was trash :/
then i thought how much vacuum is this vacuum actually pulling, so hooked it up to the Vacuum gauge, and it barely pulled 1 inch of Hg. so swapped out the cordless for the 5 gal shop vac. it pulls about 4 in of Hg. so connected it to the vacuum wiper motor. and away the wiper went. i was happy. let it run for a minute to make sure everything works correctly.
just for you guys, I shot a short video, make sure you turn down the SOUND, the Vacuum is LOUD !!
Vacuum Motor Mechanisms at Work
Vacuum Wiper Swinging Wiper Arm
videos are a little large, so may take a few minutes to initialize and run but they are cool, especially the one with the mechanisms
Link to ALL 1929 Vacuum Wiper Motor Pictures
Now it needs to be cleaned up/ remove extra grease, and then painted BLACK and installed.
Great info. Love the details on your "shop vac testing jig with baster attachment". I too like a healthy amount of grease...
thanks, hey it works great !! had to use a little ingenuity
they said to grease it liberally. and figured the new fabric in the paddle would soak some of it up.
I also made sure that all the air passage ways were clean and clear.
ok, if you could NOT view the videos, they are now on Posted via YouTube :
quicker more responsive vs trying to download and watch.... had to learn how to USE youtube again since google jacked it up!!
sent out the wiper motor to paint with the rest of my parts and it is back ready for install along with the bracket
20190311_190508.jpg 20190326_184352.jpg 20190326_184332.jpg 20190326_184340.jpg
Page 2 of 3 1 2 3
