#395942 10/04/17 01:53 PM
WSP530 Offline OP
The fuel gauge works but the low fuel light stays on. The schematic shows a relay, where is it? Is it in the sending unit in the tank or part of the fuel gauge or somewhere else.
1917 490, 1928 Depot Hack, 1925 Buick roadster, 1978 Vette pace car, 2002 Z06
Wilwood Engineering1955-1957
WSP530 Offline OP
Seeing no suggestions ,guess I will try a new fuel sending unit first then if that don't work I will try a new gas gauge in the dash, I will check it before reassembling the dash, could just remove the bulb but I like to have things work as was intended
I don't know but purchasing a shop manual would be a
great help for this and any future reference.
hood
p.k.
1956 BEL AIR 2 DOOR HARDTOP
I just looked at my factory wiring diagram and there is no relay. A tan wire that feeds 12 volts to the gauges and a pink wire that goes back to the sending unit and the sending unit has a black wire that goes to ground. I have had two 78 Corvettes and do not remember a low fuel light, maybe I never ran mine low enough. I would say the light would have to be controlled by the dash gauge when it see's low resistance from the sending unit.
