Posts: 6 |
I am From Brazil
I would like to identify if my 1950 chevy truck engine is correct. if not, what is wrong. It has this follows number on engine: HBM147698 - means TONAWANDA 216 CID 3835309 cast number - means 42-49 325 CID. is a 216 ou 235 CID?
Posts: 1,478 |
I am sending two messages on "My Stuff". See red flag. You have a 216 head from 1950 on a 1948 or 49 block. The block is 235.
This is the second time arund. I completely Identified the engine and it is as you described. The pictures show it has a later 235 valve cover with the side screws to add more confusion - but it is a 216 head.
