Posts: 3,542 |
The '57 is coming together, but I can't figure out the reasons for the following:
In the floorpan on the pass. side where a rear passenger would put their feet there are 3 factory made holes about the size of a dime; 2 of the holes are about 4" apart and the 3rd hole is about 12" away in line with the first 2.
Sort of like this:
O----------------------O (ignore the dashes)
O
There aren't any holes in the same place on the drivers' side; however directly under the driver's butt there are 2 factory made holes (dime size) in the floorpan. Like this:
Have looked in all of the books I have and can't figure out the purpose of the holes.
Can't be for seatbelts, can't be drain holes, what are they for???
Any ideas????
The rubber plugs used in those holes are shown in the CCI catalog.Part #09-26 (4) and their rough drawing looks like your description.
They are not for seat belts as the seat belt holes were drilled by the dealer in a different location and would be much larger.
Posts: 3,542 |
Chevgene,Thanks for that information, cool.
I should just plug them?
Do you have any idea as to why they are there?
