Posts: 206 |
Recently purchased a rear window frame supposedly from a '50 convertible. Correct size but it's cast aluminum. Is this correct or should it be stamped steel?
52Conv
Posts: 535 |
gpallen2,
The rear window frame on my '50 is a chrome plated casting. Actually two castings, one inside, one outside, held together by screws from the inside.
Jim
Posts: 206 |
Thanks Jim, As a "convert" from Fords, I had never seen an original rear window frame that was cast and thought it might be a repro, although the dimensions seemed correct. Guess I'll pay a visit to my friendly chrome shop! Thanks again,
Gene
52Conv
Posts: 206 |
By the way, since my car didn't have a top when I got it, I don't know the correct spacing of the bows in relation to the rear tack rail. Anyone have those measurements? Thanks, Gene
52Conv
Posts: 535 |
Allen, The Fisher 1949 "A" Series Bodys manual (available for online viewing at http://chevy/tocmp.com) goes into considerable detail about the Hydro-Lectric convertible top construction and adjustment. However, the spacing dimension is not mentioned. Indeed, convertible top fabric replacement is not even mentioned! I will measure mine it and send it to you. Jim
Posts: 535 |
Allen,
Measuring from the inside, center, lower edge of the last bow to the top of the well, 20 inches.
Jim
Posts: 206 |
Thanks Jim, trying to put one of these things back together from total disassembly is a BEAR! Particularly when you didn't take it apart! I'll probably have more questions as I get further along. Thanks again,
Gene
52Conv
