Page 2 of 2 1 2
Bruce, that may be the correct exhaust deflector, but shouldn't it be straight out rather than on an angle as shown? Or doesn't it matter? All the tail pipes I've seen come straight out the back.
ken48
VCCA 42589
Both my 47 and 41 the tail pipes came out at an angle.
I believe there is a story on this as to when they went to the side exit but darn if I can remember it. Guess Chev Nut will have to straighten us out on that.
dick
The 1941-1947 tail pipes were oval and went straight back. The 1948 was round, cut at an angle and bent to the left. After 1948 all replacement tail pipes were of the 1948 type.
I guess my memory isn't as good as it used to be.
Thanks Gene.
ken48
VCCA 42589
I knew you would come through. Merry Christmas
dick
Does that mean to avoid point deduction all 41-47 owners should take their tailpipe off and
1. straighten last bend so it comes out straight.
2. Lay pipe on cement driveway and beat end with sledge or put end in a big vise and squeeze to make it oval in shape.
Goodness, gracious I believe I have been reading Charlie's words of wisdom too long as I'm beginning to think like him. rolllaugh
dick
So Dick I guess what you are telling us is your tail pipe goes out at an a angle like mine?
Ah...So, that's how you can tell the year from the rear...!
The story is here.
Russell #38868
'48 4 door Fleetline
Thank you Russ for spending the time on Christmas Eve to look up the printed documentation on the tailpipe. I take back all the bad things everyone else is saying about you. (only joking)
gifts
Dick
P.S. And yes Bruce my pipe (as I imagine most other 41-47's are since that all we can get) is like yours
Two little notes.
The 1947 and previous tail pipes would last through one winter is you were lucky.
The bumper area of above the tail pipe would be red with rust.
That's ok, just trying to be nice while setting here by the fireplace hoping the big guy doesn't pass me by. manwre
Russell #38868
Gene: Did the lead in the gas back then cause the early rust out or was the material just not as good? Even the mufflers back in the 50's when I worked a local gas station didn't last long.
dick
Some due to road salt and a lot due to the corrosive exahust. Yes, the mufflers lasted two years. The lead helped to rot the exhaust system also.
In 1953 the tail pipes had an aluminized tip about 18" long welded to the end of the tail pipe and that helped. Also in the mid '50's Chevrolet began to sell aluminized mufflers for 1953's abd 1954's for replacement.
Guess my 48 is correct then.
Keith...! You mean your tail pipe has fallen off...?
Warm Wishes for the Holidays my friend...!
Happy Holidays to you Kevin.
PO had a new tail pipe installed that exits to the left and has a chrome extension welded on to it.
Page 2 of 2 1 2
