Thanks Tiny! So please tell me how to upload pix. I thought I followed the instructions in the FAQs but I am obviously missing something!
I'm the tech forum Moderator and one of the global Moderators on another site that uses the same forum software. That site does not allow embedded pictures in threads but does allow hyperlinks like I did for you above. I created a tutorial for the other site to aid users in posting links to photos. So while everything you'll read won't be exactly how things run here you will get the info you need to create a hyperlink because those steps are identical. No manual coding required. Once you get that down, embedding a picture here is only slightly different and I can help you with it.
<Start Here>
