Posts: 48 |
Chevgene can you email via aol.com?
Posts: 48 |
just received my master parts book in the mail As recommended it's an old one but the information is still good
Posts: 89 |
216 lifters are shorter than 235/261, no?
Mahar 51 Fleetline, 261, 3,55:1 94 Opel Omega 3,0
Comparing the lifters side by side I could see no difference.The 1941-53 216 push rods are 9/64" shorter than the 1941-55 235-261 push rods due to the taller blocks.
Posts: 48 |
Will the rocker arm adjuster make up the difference? or do I need 235 push rods?
As I mentioned in an earlier post you will need 235 push rods and rocker arms.....If the lifters are a fraction of an inch different the adjustment will compensate for it.
