Page 2 of 2 1 2
Chev Nut #361631 02/04/16 01:14 PM
I would not want to venture a guess as to what causes the vibration. Knowing how the entire driveline angle is designed from the factory would be where I would want to start and that would include also the engine.
m006840 #361644 02/04/16 02:22 PM
Originally Posted by m006840
Is there somewhere to find specs for the pinion (torque tube) angle. I am familiar with the problems of improper drive line angles from my heavy truck experience where it was one of the most common causes of vibration.
I have not seen that "pinion angle spec" listed anywhere, but, on a stock chassis, one could agree the angles would change, due to compressed engine/transmission mounts and rear spring dearching, due to wear and tear.
Page 2 of 2 1 2
