Rich47 Offline OP
I have a 250 six cylinder in my original camaro and was at a national show recently and was given a point deduction because my battery is installed backwards they said. The posts are facing away from the radiator support with negative cable facing the engine. It has been that way since my wife had the car since 1977. I ordered original style cables for it a few years ago and the only way the cablers reach is the way I have the battery now. Does anyone have information on which direction the battery should be? I have looked in several catalogs and have not found any luck in that route.
Wilwood Engineering1955-1957
What year is your Camaro?
Rich47 Offline OP
Sorry not to list year. it is a 1969.
I had a 1969 Impala and the battery posts and cables were set up just as you described in your post above.
Rich47 Offline OP
i THINK THAT IS THE WAY THEY MADE THE 6CYLINDER. aNY IDEA HOW A PERSON CAN REALLY VERIFY THAT OR NOT? i PLAN ON SHOWING THE CAR AT MORE NATIONAL SHOWS IN THE FUTURE AND WANT TO KNOW WHAT IS RIGHT OR WRONG.
When you say "national show" what show are you referring to?
Also, what does your 1969 shop manual show regarding the battery and the cables?
Rich47 Offline OP
I am having trouble finding it in my garage. But I will find it and maybe it will tell me something.
Rich47 Offline OP
Also the show was in Long Island NY in Mid September
What car club hosted the show?
Rich47 Offline OP
i think it is called the eastern long island chapter
Eastern Long Island Chapter of what national club?????
Maybe the Pharoes, as in American Graffiti. dance
Rich47 Offline OP
VCCA national Show was called " Back to the Beach".
You might want to check with the Camaro Club and have them confirm if your battery installation is correct.
Rich47 Offline OP
Would you happen to know if they have a website?
Do a search on Google for the American Camaro Association.
Steve Scott- VCCA Judging Committee
1985 Type 10 Cavalier Conv.
1986 Cavalier RS Conv.
https://nirvcca.wordpress.com/
Then the determination has to be made if the factory battery installation for the specific vehicle, back in 1969, had the top mount battery or the side mount battery. I believe that change to side mount happened in the spring of 1969. I have seen a TSB, on that change.
Rich47 Offline OP
I have not seen a side mount on a 69.
I was unable to enlarge this bulletin, dated 5/31/1969.
After clicking on the link and viewing the bulletin, left click on the bulletin to enlarge.
Bulletin refers to the side mount "recently being released as standard equipment" on 1969 Camaro, Corvette and Chevy Van.
Since the bulletin was dated May 31, 1969, and the text stated the change was recently released, it would be safe to say the change occurred in May of 1969.
http://www.camaros.org/images/ref/PSB_69-68-27.jpg
