#345377 06/19/15 10:27 AM
A couple of weeks ago I post a topic about my Chevrolet 137 Master Deluxe which I recently bought. I'vre tried to loacate the serial nrs etc. because I don't know where the car was produced.
I found a tag from the Dutch garage with a chassis and engine number. In the old days GM had a factory in Denmark and Belgium.
Engine nr 474049
Chassis nr XB6 8 547 or XB6 B 547
Does anyone recognize these chassis or engine numbers
Thx
See images on website below - just click one of them
Tag
Chevy 37
Nice!
2 questions:
1) What are those things on both sides near the mirrors? Proximity sensors?
2) What kind of engineer was Harrie or Harriet?
~Jim
'38 Master Deluxe 2-Dr
*Disclaimer*...All technical advice given is for entertainment value only, and is not to be taken seriously...
Those are the turn signals
Turn Signal
Sorry, what do you mean with Harry or Henriet
I assume it was a requirement for all vehicle manufacturers to display the engineer's name on all identification tags?
[Linked Image from green427.smugmug.com]
~Jim
O okay I know now what you mean
EIGENAAR means OWNER
The owner was the former owmer, his name is Harry
Damn, I thought I was close...guess my Dutch was way off. blush
Those are interesting turn signals. Were you required to install them in order to be cleared for driving on public roads?
~Jim
They were used untill the 50s, and it was arranged by law
The turn signals are also called semaphores. I had them on my 57 Beetle. VW used them up until probably 59 or 60 on the European models, yes required by law. In the VW world they have quite a high 'cool' factor.
Bryan Toedtli
Hillsboro, OR
1937 Chevrolet Seagrave Firetruck
1938 Master Deluxe Business Coupe
1950 Belair
1964 Malibu
The "Semaphor" signal was part of the progression from hand signals to flashing indicators. Some European vehicles had them built into the "B" pillar though I havent seen US built vehicles with them.
Does anyone know where I can find information about the serial or chassis numbers
Hello Pepperoni,
That tag is pretty informative. My USA made '37 Chevrolet Master Deluxe tag is pretty simple compared to your's. The info you are looking for may only be available in the VCCA archives. Unless someone like Chevgene has a book on European made Chevrolets.
It may take a little time, I don't know the process, but I'm confident some one will be able to help or steer you in the right direction.
VCCA # 047832
Sorry, I can't help.
The GM Copenhagen built 1937-cars, had chassisnumbers written like this:
XB GB-000.
X= Export
B= The factory code of GM Copenhagen plant.
GA= 1937 Chevrolet car with knee action
GB= 1937 Chevrolet "85" car with straight axle.
Your chassis code is XBGB-547 (not XB6B-547).
But your tag is not from GM Copenhagen, it must have been installed in Netherlands.
Here is a picture of an original GM Copenhagen-tag, from a 1939 (JB): https://plus.google.com/u/0/1061406...6011900242&oid=106140633293257147741
