Page 9 of 16 1 2 7 8 9 10 11 15 16
Russell as mentioned here's the W stamp, different then the other jacks I have with the W.............
[Linked Image from i563.photobucket.com]
BTW...Would I spend the money to have my jack shaft zinc or chromium plated, I sure would if it wasn't for haven't to remove it..I can see a big challenge with getting the catch re-pounded correctly. I'm sure our man Kevin "the metal guy "could pull it off though
ruscar Offline OP
[Linked Image from pic100.picturetrail.com] [Linked Image from pic100.picturetrail.com] [Linked Image from pic100.picturetrail.com]
I flattened the hump just enough to slide of the lifting mechanism off. The metal is fairly soft. I don't think it will be hard to re-dimple. I hope.
Strange, no UP/DOWN marking?
When did you last hear from out friend?
Russell #38868
'48 4 door Fleetline
up and down markings?yes strange.maybe under the rust? nice job on the removing..what plating have you decided on?Kevin,long time since I've talked to him,couple of months
Yes under the rust ,pics tomorrow
My opinion would be not to chrome plate the shaft unless you are going to put it on Bruce's wall for display. Wasn't chrome originally so why now. Maybe consider cadmium plating. Don't know what finish zinc gives.
Russ said he had it blasted so I assume all evidence of rust is now gone. Maybe sand to get the metal smooth and shiny then clear coat it ??
Like I said, that's my opinion and Russ should do whatever he likes and fills comfortable with.
Dick
If you can't re-dimple easily maybe drill a small pilot hole & install a metal screw. The head of the screw should be enough to keep the lifting piece from coming off and most likely you would be the only one that will see the small screw.
dick
I would guess Russell is trending towards Cad??As I said yesterday,lots of rust.here's some pics..Russell,did you just pound down the hump or did you take any other precautions not to smash the metal..
ery you guys take a look at my gray factory jack..You will see ribs on the shaft under the bumper suport...Do you have the same ribs??
ruscar Offline OP
First, the jack that I gave to Dick did have the ribs. I only have a side view of Ed's, can't tell if his has them.
[Linked Image from pic100.picturetrail.com] Yes I filled in the shaft and placed on solid surface and gently tapped it down.
[Linked Image from pic100.picturetrail.com] [Linked Image from pic100.picturetrail.com] Will probably go with zinc like on these.
Russell #38868
Zink looks good !
dick
iagree cad is more gray,although the shafts I've seen that were not rusted we're not shiny
ruscar Offline OP
Yea, who knows what my parts will look like in 60+ years. I know I lost my "shine" some years ago! sick
Another way to mash the hump would be to fill in the shaft then squeeze in a vice. But cover any teeth if the vice has them.
Russell #38868
Thanks Russell,you can probably guess I am planning to remove and plate it
ruscar Offline OP
Yes, I recall not too long ago a very wise man made the statement, "don't paint it, you will not be happy".
Russell #38868
I don't know about wise ...Just an over achiever ,as is the guy I am talking to..I would have buffed it but now I know how easy it is to remove..I must take level 2
ruscar Offline OP
Took the shaft to UPS. On its way.
Today, I made part one of my "re-dimplier", part two tomorrow. stressed
Russell #38868
So you sent the shaft out for plating ?If so what are you working on?
ruscar Offline OP
A way to bump the hump back out.
Russell #38868
So Russell if I understand correctly, you are fabrication a tool to recreate the stop on the shaft??Love to see that
ruscar Offline OP
If it works, you will. Just too bad the guinea pig will be my newly plated jack.
Russell #38868
Should have kept the one you sent to me. Want me to send it back when it arrives ?? Hate to see you mark up a newly plated one when you are not sure if your procedure will work.
Dick
ruscar Offline OP
The shaft on that one is only 1" x 1". This one is 1 1/8" x 1 1/2". Yours should arrive today.
If it does scuff it some, I fell sure it was scuffed when it was done at the factory also. Stands to reason to me.
Russell #38868
I don't think I have ever seen anything here on chat so researched and talked to death than the jack for 42-54.
I'm sure that it is a relief for all the 47-48ers to have something interesting to talk about. What with all the boring topics that are inherent to those stinkin fleet lines.
I sure am happy for you all. And, I hope you soon create a third and fourth parts to the thread.
Your thread sure is interesting to the rest of us out here. Is too! Much better than watching paint dry or grass grow. Keep up the good work of your research. May you will come to a consensus about such a simple thing soon. Btu then what're you going to do. Talk about Fultons? Just shoot me. dance
Best regards to all you 42-54 owners with the right and wrong jacks. And to the 47-48 fleet liners I think it is mighty thoughtful to include all the rest of the folks in your forum into the discussion. Reaching down to those not so far up the pecking order must be a humbling experience. Is too! Agrin
ruscar Offline OP
Having read and re-read your post, it became apparent that someone must be holding a gun to your head. Not to worry, the authorities are on the way.
Thought while you are waiting, you might to go down to parts wanted thread and read the thrilling discussion on the tool kit bag by us same '46-'48er's. Good stuff. Is too. Agrin
Now, back on subject. please
Russell #38868
Not to worry Charlie I will get right on that Fulton topic
