Posts: 3 |
I have just purchased a 55 1st series 6400 which had the original 261 engine replaced with a 58 261. The previous owner moved the radiator forward and down to accomadate the long shaft water pump on the 58 engine. I would like to move the radiator back to the proper position. Is it possible to mount a short shaft water pump on this block and if so what year would match the bolt pattern on the 58 block and where could I find one. I have had no luck with local auto parts stores. If anyone has any other solutions or ideas I would appreciate any and all help. Thanks
Posts: 562 Likes: 1
Posts: 562 Likes: 1 |
Dave Folsom in Maltby, Wa. sells modified pumps for this purpose, he may be able to help. 425 485-0173. Good luck, Dick.
Dick
Posts: 3 |
Thanks for the lead Dick. Dave sells an adapter plate that allows one to mount the older short shaft pump on the newer engine. Thanks again, Rico
Posts: 562 Likes: 1
Rico, glad to hear Dave was able to help, he does a lot of this type stuff for a living and is very good at what he does.
Dick
