Posts: 2,262 Likes: 6
Posts: 2,262 Likes: 6 |
I'm building up a horn for the '29 project I'm working on and a few assembly questions have arisen. I looked at the horns I have on my cars and in the parts bins and they are all put together differently. The questions:
--Do the screws around the rim of the horn go in from the back with the nuts and lock washers on the front, or vice versa?
-- Does the Klaxon label go on the back or the front of the horn? At what o'clock position?
-- Does the horn attach to the mounting bracket by having three longer screws in that part of the rim and then adding a second nut with lockwasher to secure it to the bracket, or is it all held by one nut?
Dose the horn attach to the mounting bracket from the rear or from the front?
Any photos of the correct setup would also be appreciated.
Thanks for any help you guys can provide.
All the Best, Chip
"It's wise to choose a SIX"
Posts: 513 |
Hi Chip I have about 15 of this 8C horn and I think this is the correct month of the label and bracket Regards Arvid ![[Linked Image from i.imgur.com]](http://i.imgur.com/8brNRee.jpg) ![[Linked Image from i.imgur.com]](http://i.imgur.com/AxBgMjU.jpg) ![[Linked Image from i.imgur.com]](http://i.imgur.com/YCUbe1U.jpg) ![[Linked Image from i.imgur.com]](http://i.imgur.com/bjUnaZo.jpg) ![[Linked Image from i.imgur.com]](http://i.imgur.com/3PYL1lB.jpg) ![[Linked Image from i.imgur.com]](http://i.imgur.com/RdN7SAe.jpg) ![[Linked Image from i.imgur.com]](http://i.imgur.com/NGqkAEB.jpg)
Thanks very much Arvid. That is exactly what I needed to know.
All the Best, Chip
