Posts: 52 |
I need help locating the master brake cylinder on a 47 wagon. I just purchased the car and need to check fluid levels. Additionally, what type of brake fluid is recommended? Thank you...
You can purchase a reprint of the 1942-48 shop manual from the Filling Station, www.fillingstation.com The manual will tell you all you need to know about the Master Cylinder and etc.
Posts: 3,136 |
Should be under your foot...Carefully roll back the floor mat and remove the plug in the floor...You'll need a socket/extension and a ratchet wrench...Bring a flashlight and a funnel...3 dot works for me...Good luck...
Posts: 1,069 Likes: 9
Posts: 1,069 Likes: 9 |
Where are you located in N CA?
