Page 1 of 3 1 2 3
#317443 09/01/14 05:40 PM
This forum seems deader than last week's road kill.
So, being a 41 owner and just wanting to be helpful and possibly pump some life back in a forum that should include the 41 in the first place, I thought it would be a good time to ask a couple questions about those twins: The 47 and 48. (Whee, long sentence right there. Was too.) Here goes:
Note: some questions may apply to 42 and 46 as well.
a. Assuming that Chevrolet has always planed far ahead of production, why was the loop over the plastic eliminated in for 48? Seems that the fancier accessory would have been reserved for the 48 instead of the 47.
b. I've seen red needles in the instrument panel of either 47 or 48 or both. Which cars and years (if applicable) got the red ones instead of the clear ones?
c. Exactly what engine differences were made between the 47 and 48?. I know Gene has mentioned this several times but I still don't know them. Something about valves, rods, inserts, valve rotators, etc. Not sure of the forgoing applies or not.
d. Was the center vertical bar setup in the grille a two piece or one piece deal?
e. Do most judges look for 15 inch rims and tires on a 47? Do they care?
f. Is there any difference in the woodgrain in a 47 and 48?
g. Which models had the upright chrome pieces below the taillights. Was that just an accessory?
h. Were the thicker, on one side, Fleetline taillight lens carried over from the 41 to 48 on some models. If so, which ones.
I. Other than the little "47" and "48" tags on the bottom of 47 and 48 radios, was there any difference in the two radios, either in parts, performance or appearance?
j. Why are 47 and 48 owners insistent on sticking a Fulton on the critter. It looks like grandma's bonnet. Yes, and the worse looking one she had, too.
k. Were there any differences in the 47 to 48, that I haven't mentioned? If so, what?
l. Were there Areosedans (spelling) in all body styles for both years? That is, in both the cheaper model as well as the higher priced models.
m. Was the Fleetline chrome available on the convertible and station wagon?
n. Other than most suffering the Fulton itch (read plague), the 42-48 owners seem to be right smart people? Why is that? What am I missing? Agrin Agrin : tooth
a- so it would look different, not better.
b- red when new. some faded if got a lot of sun,
c- Thin bbabbitt rod and main bearing. Rods required less frequent if any adjusting. Precision main bearings eleminating line boring and just one could be replaced. New two grove valve stem and caps with O ring seal. Revised cam timing for better high RPM performance.
d- The T bar was one piece and a litte spinner ornament/bolt held it in place
e- depends on the judges knowledge and eye sight
f- no
g- Fleetline and Fleetmaster
h- Fleetline 4 door from 1941-1948 had the thickrer on one end lenses because the tail light body stuck out farter on the inner side.
i- not that i can think of.
j- personal opinion
k- Interior upholstery colors went from a brown color to more of a gray color.
l- All Aero Sedans were Fleetline only
m- Fender mouldings came on Fleetline 2 door and 4 door only.
n- the boat
Gene -
n answer, poignant.
Charlie -- You forgot to mention your distain for the skirts as well as the visors.
Kiddingly,
Jim.
Charlie,
Thank you for your attempt to revive this long suffering forum. Since Bruce, (Chef-Chevy), Dale, and I have more or less, wound up our projects, the forum has indeed been anemic.
Boy, Gene has covered most all the bases.
Looks like you plea to have the 41's moved up to join us has fallen on deaf ears!!!
Again, thanks for the infusion.
Yes n. answer from Gene is bana2
Russell #38868
'48 4 door Fleetline
Charlie:
There's no skirts or a Fulton on my 48 Fleetmaster,but, I bet the big fat tailpipe end sticking out from under her rear bumper would get to you.
Regards:
Oldengineer
I've no distain for fender skirts on the fleetlines. All those chrome pieces give the car a streamlined effect and look real good. Unlike the Fultons which give the car a ______ (fill in the blank) look.
Gene, I ani't missed no stinkin boat! Agrin
Jim, Poignant? hood
Great thread! Thanks for starting it Charlie!! Loved Gene's answers, especially "n". :-)
Dale Carter
VCCA #8661
1948 Fleetmaster Convertible
1948 RHD Stylemaster Sedan Delivery
1948 1-Ton Tow Truck
1967 Camaro Coupe
Gene and the rest of you who have let this one go without comment"
I don't understand the answer to "b."
The answer is clear enough but I can't understand how the amp, gas, batt, oil pressure, speedometer and clock pointers/needles started out red and changed to clear owing to the sun shining on the dash.
Seems something wrong with that answer. Maybe I didn't state it clearly or Gene is on to something else, whatever that is.
BTW: I've taken note of the nice 41 pictured on the front of the latest G&D. I special note of the Fulton. I'm certainly not important enough to take that as an attempt to drive me over the edge but I have been thinking of "popping a cap." And, if I see one more Fulton before recovering from this latest setback, it may do the trick.
Mercy! smash
BTW2: Were Fulton's fastened to 47-48s to protect the dash pointers/needles from the sun? Even that wouldn't justify their use. If you don't have a shelter then park under a tree. Even more mercy! I can't stand it! willy
Charlie,so sorry about installing the Fulton,if seeing them displayed so often,Kens 48 and I will sell them back to you,I know you want to protect the color on your gauges...Mine are still a nice bright red,just as when purchased nos,not to mention the deteriorating grain on your dash,mine is still as good as new.... haha
Charlie - I'm with you on the clock and speedometer needles - my used gauges are this nice pretty amber color (that I actually think are nicer looking than the red ones), but we've gone down that road before and all the NOS ones are red and I saw a couple of real low mileage 48s at Hershey last year and their needles were red...
Dale Carter
VCCA #8661
1967 Camaro Coupe
The gas gauge, temp. gauge, etc. had red painted metal needles almost like a 1941. They would fade over time. The speedometer needle was some kind of plastic and would also loose its color. I remember these cars when they were almost new (1948's were 2 years old when I started in the dealership) and every thing was new and bright.
Well Charlie, your disdain and ramblings about Fulton visors, especially when installed on fine 47,48 Fleetlines has finally gotten to me. Rather than remove the Fulton on my 48 Fleetline Aerosedan...........I recently sold the car to a gentleman in northern Vermont who really appreciated having it on the car!!!! I would have loved to keep that car that I put so much time and love into, but your constant belittling of the car with the Fulton was too much for me to bear. My personal opinion was that the Fulton enhanced the lines of the Aerosedan. I guess that's why it was so popular "back in the day". How could all those people be wrong Charlie?
So, yes, Chef Chevy and Ruscar, I did sell it. It hurt a lot, but Charlie just wouldn't let up and I couldn't take it any more.
I experienced severe withdrawal symptoms after the sale and finally succumbed to the purchase of a 1971 Chevelle sport coupe which I am thoroughly enjoying even though it has no Fulton visor, although I'm working on how to install one just to keep Charlie on his toes.
I'll still be looking in here on this Forum (and watching Charlie wherever he may go) as I learn about the Chevelles...hello Mr. Miner............
Fultons forever........
PS......Charlie, I had to buy sunglasses. The tinted windshield in the '71 just didn't do it like the Fulton did!!! Some of us need more help than others.
Mercy, it's been a great ride!!!!
ken48
VCCA 42589
Ken,
I really do appreciate your effort to help me cope. Selling the car was an act sincerest sacrifice. And, done just for my sake. (picture me with a bath towel to my face a-sobbing uncontrollably with great sense of accomplishment. Oh, the joy, oh, the sense of achievement you have provided me.) The only thing now is for the new owner to up and junk the Fulton. Agrin
I hope you enjoy the 71. Maybe a picture here to show it to us. Not to prove your sincerity, of course, but it wouldn't hurt none.
Maybe other owners with Fulltons will see the light or be sufficiently badgered to follow your lead. One can only hope.
You're such a swell guy. You know that? Are too!
Best,
BTW: I'm going to work on CC a little bit harder now. beermugs
My goodness Charlie........the Fulton was why the fine gentleman bought the car!!! luv2
Here's the new '71...... cool
[Linked Image from i100.photobucket.com]
More photos to come in the near future.....in the correct Forums of course.
.....and just for old times sake here's the '48 one more time....
BTW Charlie, the '41 SD Business Coupe featured in this month's G&D (page 14 in case you missed it) looks mighty fine with the Fulton, don't ya think? Agrin
ken48
VCCA 42589
I'm accually still on the fence with this Fulton thing...
I have a couple, but there not on the car...Yet. I hold'em up
to see how'ed they'd look, but...Just can't bring myself to bolt it up...A real head scratcher...
Sorry to here the '48 is gone, Ken...Hope he takes good care
of it...Oh, that's a nice SS...!
Hey Kevin,
I felt very comfortable with the new owner of the 48. I'm confident he intends to keep and maintain it as original as possible. He called the other day to tell me he found a correct radio for it.
The Chevelle has some minor needs that I'm working on, but it is in generally very good condition.
I wouldn't want to sway your thinking on the Fulton installation, but here's some installation info that might come in handy someday.....
http://www.indfloorcoating-repair.com/fultonsunshield.htm#CHEVROLET
For some reason this info opens in the middle of the page, so make sure you scroll up and down to see all the instructions.
ken48
VCCA 42589
I wanted to make some remark, but, at a loss for words right now! sick sick sick
refWell, if it makes you "feel" 23 years younger. beermugs
Anyone with Photoshop? Cut that visor on the '48 and paste it on the '71.
Russell #38868
I've tried to stay out of the whole "Fulton Fight", but now it's just gone too far! With Charlie shaming and harassing Ken into selling the '48, I really think he's gone and committed a worse sin by buying the Chevelle, and not taking the obvious proper course of action.
For my own discerning tastes, I find that although the '41-'48 cars with a Fulton are not horrible… they are not perfect. I find the arms at the outer edges to be distracting from the overall "sweep" of the near perfect styling. Now, I think to remedy the situation, one merely has to look at what GM did to fix it themselves. That's right… they came out with the most beautifully styled bodies ever to grace a car for 1949-1952. And to make things perfect, they made the visor perfect… and in America, stuck it on the Pontiacs! (the two piece Chevrolet offering looked bent. As bad as a Fulton on a '41!) Here in Canada we were offered the one piece Pontiac visors at our Chevy dealers, and drove around in perfect cars with perfect visors… able to read our perfect speedometers. We'll have to go for a ride sometime, Charlie. I'll convince you to stop messing around with that '41, and get working on your perfect 1950...
thanku iagree
I like the one piece visors and think they look cool on the 49-52s. It's those other visors that I think distract from the beautiful lines of the car. Especially on a 41.
Ken,
That Chevelle looks really nice. Owing to the Fulton, I think you made a wise choice. It looks like a show winner.
Brewster,
A visor on a convertible will not look too cool. Your being a top-notch modeler, I find your comment about the lines of the cars being destroyed by those stinkin futons right on point and worthy of heed by those sporting(?) those things. Agrin
I think I'm going to drag the 50 out and put a set of rings in it and run it as rat-rod. The 41 project is at a standstill and I don't give a rat's arse anymore. hood
Sorry Charlie,My 48 with the Fulton intact go no where,don't even try!Mercy!!! devildance
Ken my condolences
Charlie… I never meant for you to think of putting the Fulton on the convertible! That's even worse than putting it on a '41 coupe!! I just meant for you to get the convertible out, and feel the prestige and fulfillment that comes from riding in GM's best offering ever! If you want to ride in the shade, I'll take you for a spin in my sedan and you can enjoy the shade of the visor…
what am I to do??? follow Ken and sell my 41 with the fulton or not seriously though ever since I had the car I have been debating weather to keep it on remove it. need help!
PS. not sure it image will appear not good with computers.
http://i662.photobucket.com/albums/uu343/kens41/290.jpg
kens41"
very nice,lower it just a it but certainly keep it,my avitar pic is before I lowered mine...I'm sure I am one of the few that would say to keep it...If its a fulton,you would have to repair the holes in the jam if removed
I would get rid of the fog lights as they are not correct and distract from the nice appearance of the car.
Agrin devil
Very nice car!
To Fulton or not to Fulton, that is the question. 'Tis nobler to keep true to your own aesthetic opinion and not fall prey to those with different perspectives.
For example, if you love chocolate, but a friend hates chocolate, are you going to give up the sweet because someone else doesn't like it?
'Nuf said.
Page 1 of 3 1 2 3
