#308249 05/16/14 01:06 PM
Twigs Offline OP
Some people are telling me to put longer spark plug in my 39. So I got AC 45FF should I put them in?
Thank you,
Twigs
1939 Chevrolet Master Deluxe 4dr sedan
VCCA# 50190
Twigs #308253 05/16/14 02:16 PM
NO-NO-NO-NO.
I have used AC45R plugs in my '39 for years and years with good results.
Why would the extended thread be a good idea? It would stick into the combustion chamber to far and cause problems.
The 45FF is among other things a Corvair spark plug and designed for aluminum heads.
Chev Nut #308257 05/16/14 03:44 PM
Twigs Offline OP
Thank you sooo much...they were telling me the long ones will get more Oil....
Thank you,
Twigs
VCCA# 50190
Twigs #308265 05/16/14 04:48 PM
Chevgene,
Did you mean AC R45 ?
Dave39MD #308274 05/16/14 05:32 PM
Yes......long ones get more oil? never heard that one before but if the car is burning oil the longer plugs will get more passed by them oil and foul out.
If the engine actually is burning oil and you do a lot of low speed driving you could go up one heat range to a #46 AC.(R)
Chev Nut #308282 05/16/14 06:49 PM
Twigs Offline OP
Thanks...we don't burn oil..but do some low speed travel in parades..
Thank you,
Twigs
VCCA# 50190
Twigs #308765 05/23/14 11:58 AM
Twigs Offline OP
I found AC R45TS is that the same?
Thank you,
Twigs
VCCA# 50190
Twigs #308766 05/23/14 01:03 PM
No. The TS stands for tapered seat. The R45 will be a flat seat with a gasket. R45 is still a good ACDelco number and is available most everywhere.
Dave39MD #308773 05/23/14 04:54 PM
Twigs Offline OP
Dave,
Thanks a bunch..I will look for them...are Champions any good?
Thank you,
Twigs
VCCA# 50190
Twigs #308780 05/23/14 06:00 PM
I always stick with AC's since they were the OE plug. Since I always have had Chevy's I had to reason to sample Champions.
Try your local traditional parts store if you still have one or NAPA. If NAPA does not have them they can get them very quickly.
Dave39MD #308787 05/23/14 08:13 PM
Twigs Offline OP
Thanks Dave ..I will stick with what works for our Chevy's..AC R45's I'm coming for you..
Thank you,
Twigs
VCCA# 50190
