Page 2 of 2 1 2
Weak battery condition was dealt with already in Dan's post.
1930 Coupe 1935 Coupe 1953 210 1954 1-ton automatic 1959 GMC half-ton
Update on the starter I was going to have converted to a 4 field coil starter. Evidently it is not possible to put 4 field coils where there was two without going to a different starter case on this starter. The shop did find a grounded field coil however, so they replaced both field coils. Huge huge difference in hot and cold starting now!
Glad to hear you found the problem and not surprised at the cause.
Where are you finding the 0000 cables?
b uy 0000 cable at a welding supply store
I had my 0000 cable made up at my local starter/alternator repair shop.
I have no doubt that the 4/0 cable works fine, but I think it's a little bit of overkill. Most heavy trucks running 10 times the battery capacity and with starters drawing way more amps typically use 2/0 cables.
Right...but the big trucks (like semi trucks) are running 24 volts (and sometimes 36 volts) and not 6 volts. A 0000 cable on a six volt system is definitely not an overkill.
Try 4 G4D-165 batteries connected to give 12 volts running and 24 volts starting using a series parallel switch and 2/0 cables.
Most all the older (60's and70's) used group 4 6 volt batteries and many that had 24 volt starters were converted to 12 volt which was the most common then and still is.
None that I know of today are using 24 volts as that's only common on construction equipment. . I've worked in the truck parts business and retired after 46 years. During that time I had experience with White, Autocar, Western Star, Freightliner, Mack, Peterbilt, Ford, Sterling, Isuzu, and GMC and Chevrolet. I've sold thousands of 6 volt batteries and have made up many battery cables and 99% were 2/0 cable.
Cool! I used to work part time as a fill in at a truck electric shop and the majority of the trucks that came in for electrical repair had 24 volt starters.
On a 6 volt system 00 cable is definitely fine, but a 0000 cable is even better. I switched to a 0000 cable on my '51 Chevrolet and it made a world of difference, especially when starting the vehicle hot.
Page 2 of 2 1 2
