I am fairly new to posting, so I will apologize in advance if I mess this up.
We are in the process of putting together a tool kit for our 1932 coach. We have been doing pretty well in locating items on eBay, using Ray Lemasters' and Dave Miner's write-up as a reference.
However, there are a couple of items that we can't seem to find pictures or dimensions for. They are part #348905 wire wheel hub wrench and the correct jack for 1932.
Does anyone have pictures and/or dimensions of those two items?
Thanks!
Mark
Support The VCCA!
If you are talking about the Wire Wheel Lug Wrench it is 22 1/4" long. Shaped like a speed wrench for a socket set. Has a socket for the lug nuts on one end and looks like a screw driver on the other end. The screw driver end is used to remove the hubcap. I hope this helps some.
Joined VCCA June 1, 1961
Thanks, Back Roads. That does help.
If anyone has pictures of the 1932 wire wheel lug wrench and jack, that would be appreciated as well.
Mark
picture posted in member photos section.....
Member 45+ years, been around since the beginning !
Mark I have sent you a PM , click on the flashing envelope next to My stuff
JACK
Thanks, VCCA Son!
I may never find one, but at least now I know what I am looking for!
Mark
Thanks for the PM and the instructions for how to access it, Jack. I have replied. Much appreciated!
Mark
