Hi all,
there is a fair chance I can get my hands on an early 30's Chevy Truck project!!! I don't believe it until I see it, but planning the resto is underway. My first major issue is surface rust. The body is covered in a thin layer of surface rust. Since I am in the Netherlands, chances are that if I don't cure it right away the sheet metal is gone next week...
My first idea is a Scotch Bright pad in a polisher machine, clean everything up, wire brush for the nooks and crannies, and set the lot in primer.
Then I read about stuff like this:
http://www.rust-cure.com/Sounds to good to be true. Anyone with good experiences with such products? Preferably ones available in Europe / the Netherlands?
Cheers,
Hugo
