As I think that maybe with the low cranking power of my battery and a light duty positive battery cable (stated in a different post) I may not of had the speed I needed to get the commpression. :confused: I now plan to fix the clutch plate and give it a pull to start it.
Like Chev Nut mentioned, I to wondered why all pistons were so low and quite even. My tester is new and worked on my boys car so this test should answer my questions one way or another if it starts. If not, apart comes the motor.
jerrygolf
