Davis,
Here is my take on this issue:
If the flues and fins are open in the radiator
and the water pump is pumping
and the block is clean
and there is no gases going into the water jackets
and the water is half-way the top tank when it is cold
and there is no stuck thermostat
and there is no collapsing or collapsed (interior) hose(s)
Then it is not overheating. You may be hallucinating, on something more potent than some spirits made without taxes being paid, or that filter thing you told us about is a-messing up or the sending unit bad.
Given the above positive conditions, there just ain't no way, that I can figure that it can overheat. Get hot yes, but overheat, no.
Charlie
