What happens to your radiator when the engine isn't properly flushed after being hot tanked. What you see below isn't the top of the coolant because the coolant has been drained. There isn't even a petcock in the radiator. It's a wonder the engine wasn't running hotter than it was. The radiator is coming out next week to be tanked and leak checked.
Regretably, there has to be a lot of that stuff still in the block.
I suspect that as well so I also drained the block in preparation of flushing it as well. By comparing the coolant that came out of the radiator to that coming out of the block I think that most of the crud is in the radiator now. Even at that I'll be pushing the car into the driveway, pulling the thermostat and doing a good flush of the block as well.
I know a bunch of drag racing guys that use this stuff. They swear by it. I have no idea if it's a great product or just snake oil.Maybe someone will chime in.
It would likely make for better heat transfer but I don't know that for a fact. My "common sense" tells me it's not snake oil but again I don't know that for sure.
You might want to fill the system to keep that sediment wet to prevent it from drying and caking til you're ready to pull the radiator. Surely a lot of it would flush out through the block drain with the engine at a healthy idle (if it ain't too cold outside). If it drys it will be more difficult to clean out.
Having spent years among the Drag Racing community, it is a product that has proven itself to be extremely reliable in helping water in it's ability to lower engine coolant temps. But you must take into consideration that the engines I'm familiar with have been hot tanked and inspected for cleanliness before the expansion plugs have been installed. I'm not sure how well it will work in a contaminated engine block. So if you feel that the cooling system has been thoroughly cleaned then it should work as advertised.
I seen that additive used and it does help. I know when I was involved in dirt track late models we ran straight water as did 99% of the cars. If antifreeze would have been used along with water I don't think it would have been as effective. My opinion anyway. Don
After my research and experiments with flushing my radiator ( I did try this on my Toyota fork lift radiator ) with Muriatic Acid...I found it believable that you should flush again with plenty of water and even add a neutralizer ( like baking soda ) to insure you get rid of the "flushing" agent or traces left behind will continue to "etch" and probably leaving you with the situation you have now...
I wonder if the flushing of your block was satisfactory but they simply forgot to rinse it...(?) Or didn't rinse well enough...(?) Just a passing thought...
I don't have an answer for that but I CAN tell you it WILL be thoroughly flushed when it's again on the road.
