Page 2 of 2 1 2
kevin47 #257866 10/14/12 05:19 AM
wawuzit Offline OP
I wondered about that but the heat kit only had one tapped out hole. I could tap another hole and see what that does. I'll try it. THANKS
wawuzit #257877 10/14/12 09:05 AM
The heat kit I have is for only one tube,I am trying to find a corvette manifold before the new motor goes in but if I cant find one reasonably priced will add the second tube.
VCCA #45194
wawuzit #257879 10/14/12 10:37 AM
Steve,
Before you drill a second hole, take another look at pic that Hayree38 posted. You could add a "Y" block at the single hole and bend new tube similar in shape to what you see in the pic.
VCCA # 047832
dfd37chev #257887 10/14/12 01:09 PM
Sounds like the same situation...Just a little bit closer to the hole. laugh
I would say you need that in-an-out flow to, well, get that flow.
kevin47 #257894 10/14/12 02:51 PM
wawuzit Offline OP
I drilled and tapped another hole and installed the 1/2" tube fittings. I'm trying to find steel tubing that can be bent with hand benders. Some of the steel tubing is not meant to be bent. I'll call around tomorrow. Photos are sure to follow.
wawuzit #257895 10/14/12 03:09 PM
1/2" steel Conduit used in electric work in easily bent with a conduit bender, a very cheap tool that can be bought in any hardware store ...ED
ED1938 #257899 10/14/12 03:39 PM
wawuzit Offline OP
I did have 3/8 " OD tubing ,which was advised by the Fenton Co., I've upgraded to 1/2" OD tubing. I did have both sides of the split exhaust tee-d and going into one hole in the heat kit. Now I will have a 1/2" tube from each side going into two holes in the heat kit. I'm trying to build a larger fire in the stove... Agrin
I'm gonna keep this old chevy from running cold I hope.
wawuzit #257901 10/14/12 03:59 PM
Harbor Freight has a 1/2" steel tube bender for about $40.00. But you might be able to have your local muffler of machine shop to bend it for you cheaper.
Just a suggestion.
idea
Ken's 1940 Special Deluxe Sedan
1970 Cadillac Hearse
wawuzit Offline OP
Thanks. The larger tubing won't look as neat as the smaller tubing, but the results maybe will be worth it. The outlets on the split manifold are pointing at odd angles. It's going to look strange. I guess the design was needed to fit many different models of inline chevy engines and bodystyles.
wawuzit #257927 10/14/12 09:30 PM
[img:left]http:// https://picasaweb.google.com/m/view.../5736997592466145777/5799219100942062754[/img]
This what your looking for?
Don, It won't open for me... It's asking for to sign in. ???
[Linked Image from lh5.googleusercontent.com]
wawuzit Offline OP
Is that the correct price? Is it for a 235? Condition? Where do I send the money?
wawuzit@comcast.net
Page 2 of 2 1 2
