Hi jeeper18
I don't consider the heat riser valve to be necessary, and I'm up here on the cold Canadian prairies. 🙂
Knowing that nearly all of them end up stuck, I've blocked mine in the non heating (warmed up) position.
I'm thinking it's better to have it seize there than in the heating position.
My '46 probably runs a little on the lean side, but even at that, all it needs is to leave the choke out some for the first few minutes to keep it from missing and bucking on acceleration.
I don't think your delete plate would be terribly detrimental performance wise, but, that said...
The problem I see is that you still need to use a gasket in ADDITION to the plate against at least the intake manifold.
That will create a misalignment problem between the exhaust and intake manifolds (up and down that is) at the gasket surfaces where they bolt up to the head.
That may or may not be a problem, but probably won't make anything better.
