Posts: 3,136 |
The heater fan runs smooth and quiet but you can stop the blade by just touching the blade. Not very strong. Steve...It's time for a new motor...They're a little pricier than 12 volt, but easy to get...
Posts: 4,446 |
I'm calling my stock broker and have him change all my investments to "chevyofthe40s" and "The Filling Station".
I figure about the time I get everything 6volts in good shape I'll have a buyer that wants the car if I'll change it over to 12volts..grin
Charlie are you listening?...
Posts: 1,135 |
That's true.Just a bad idea I guess. I'll stick with 6 volts.  Steve ..I would stick with 6 volt......If your heater fan don't spin fast enough for you, hook up some bicycles pedals to it and then you can also benefit from the exercise....or invest in a Hamster in a cage wheel (if you want to be Green)...ED
Posts: 1,441 |
I think I will have to get some of the thicker battery cables for my 37,it has been converted to 12 volts but bigger is always better.
VCCA #45194
The 12 V cables are about half the size of 6 V cables. That is because they carry only 1/2 the amps.
Posts: 825 |
i had slow turnover and invested in ooo guage wire, now it startes first turn.......
never give 100% unless you are giving blood.
Posts: 3,136 |
I would imagine you now have extra current for the coil...
Yes better current but the significant consequence is higher voltage at the coil and therefore hotter spark.
