Posts: 2 |
Is there a kit to replace the vacume shift with a manual linkage?If not what is the best way to repair one that is hard to shift?Thanks bill
Bill,There was a kit made years ago to eleminate the vac. shift.It was not made by Chevrolet and was difficult to adjust and seldom worked well.I see them on eBay from time to time.Try to lubricate you present shift cylinder.The instructions are in the shop manual.Removal is necessary.Hydralic jack oil is used.Also cleaning the air cleaner may help-its in the frame.I don't know if removing the hose from the top and adding some oil will get the oil into the cylinder.It would be an easy test.(don't run engine -it will suck it out right away)
Hi bills396, If you can't get it to work, remove it and ship it to me, and I will rebuild it.
Posts: 2 |
Thanks guys I will try to lube it I have the shop manual.The car belongs to my father in law and sence im a machanic I get to work on it.I have never worked on the vacume shift before so I thought it would be smart to ask first.Ive got a 68 Chevelle SS that I restored so my father in law got the bug for an old car too.
