#247634 07/02/12 09:58 AM
For a 48 aero
I need the 2 lower moulding strips quite badly
does anyone have a resource???thanks
I'm not sure what you're referring to. Could you expand your description? Thanks!
Dale Carter
VCCA #8661
1948 Fleetmaster Convertible
1948 RHD Stylemaster Sedan Delivery
1948 1-Ton Tow Truck
1967 Camaro Coupe
I would assume you mean the lowest of the low...front-fender to the back-fender, 2 inch's wide x 6 feet long...? The right side is commonly used for curb-feeling...?
Ahhh - the rocker mouldings? The title of this thread (Door Panel Moulding) threw me.
Dale Carter
VCCA #8661
1967 Camaro Coupe
Sorry guys...."Interior Door Pannel"...On the 48 Aero there are 2 stainless garnish moulding at the lower part of the door pannel,it accents the top and bottom of the vinyl piece of the pannel...At least this what I've seen...The door pannel moulding on the 4 door is different,they are a thin curved piece
Hey guys....
Read the description Bruce gives above, then look at the pictures below. You'll see what he's looking for.
[Linked Image from i100.photobucket.com]
Bruce, I wish I had a few of those for you, but alas, mine are on my Aero (which is 3000 miles away from you......and locked up in my barn). Good luck finding some.
ken48
VCCA 42589
Those door panels are "drop dead" gorgeous.
devil Agrin
Thanks Ray. blush They're from Hampton Coach circa 1996.
ken48
VCCA 42589
Yes and with out the 2 stainless strips mine will be an ugly duckling...Can some one help me find them,need 4 in total...
Ken give me a couple of weeks and then I may need measurements for posible fabrication....Maybe Kevin can make me a set???
Bruce.....you just give me the word and I'll be happy to do some close up pictures and label them with dimensions.
Just stay away from my barn...... wink
ken48
VCCA 42589
Can you provide the dimensions on the stainless? I parted out some Aerosedans and may have saved some of the stainless. These pieces don't look familiar, but you never know...
Dale Carter
VCCA #8661
1967 Camaro Coupe
Well Ken if you could wonder over to the barn with a tape measure and post the measurements of the pannel moulding for decarter I my be in luck,thanks
OK Bruce, just came back from the barn.......
Here are the dimensions...
44" long x 3/8" wide x 3/16" deep
Let's keep our fingers crossed and hope that Dale has some squirreled away in his spare parts pile. If you need any close up pictures, I can do that tomorrow.
ken48
VCCA 42589
Lots of thanks Ken,I've got my fingers crossed.I'm thinking they could be attached with a cut down version of the bolted rocker moulding clip...Here we go again i got the cart before the horse
Whoa boy........don't make the clips just yet. You haven't even asked me how far apart the two strips are yet bigl laugh bigl wink
Hey, tomorrow I'll take a closer look at how they are attached.... and maybe even get mounting location dimensions for you wink
Have a good and safe 4th. patriot
ken48
VCCA 42589
The bad/sad part is the way they are held on. The strips have a small nail/brad welded on about every 4". They poke through the panel and are bent over. I haven't had the nerve to try and straighten mine enough to install, if I ever get there. Good luck.
Russell #38868
'48 4 door Fleetline
Hmmm. Guess I don't know what I have. My stainless mouldings that I thought might be from the inside door panels are only 33 inches long. One pair is 1/2 inch wide and the other pair are only 3/16 inches wide. Any guesses out there? It's been too long since I took them off the car. I had them in the same box as the outside belt mouldings from a '47 Aerosedan I parted out. Oh by the way, those outside belt mouldings are on eBay at the moment if anyone is interested.
Dale Carter
VCCA #8661
1967 Camaro Coupe
With reference to the "brads" that attach the trim strips to the panal. Most of mine were broken off, making attachment impossible. I took some small brads, bent a short "L" on the end for added contact area, and used a low temp silver solder to attach them. It worked fine, with some discoloration on the stainless which buffed out. Fairly easy fix.
52Conv
I know about the little nails attached to the inside of the moulding..As I said I have pannel moulding for the 4 door which are curved in a rouned "L" shape..The little nails are somewhat brittle..please keep your eyes open if you would please,thanks
Russell if I am correct your trim pieces are different then the Aero?
Ken one more favor could you get a few more pics of the moulding especially the ends of them..I searched e-bay all day today and think fabrication will be my only choice....Big bucks!!
E-bay all day,no moulding but found some other goodies pineapple
Bruce....getting ready for dinner right now. I'll head out to the barn a little later with the camera and get a few shots....close up....especially the ends.
Just for your info Bruce, I posted a want ad on "the other Chevy Forum" (ChevyTalk) looking for these trim pieces. We'll see if anything turns up there.
Be back later....I hope.....because we just got a severe weather warning.....thunderstorms in the area.
Update........
OK Bruce, see if these pictures are helpful. Dark in the barn, had to use flash.
Later
ken48
VCCA 42589
Thank you Ken for all your help.
I thought while I was at it I would post pic's of what I Think is the 4 door trim,a close up of the nail thingy's and a sales doc.It looks like the 4 door also has 1 not 2 piece of trim on the vinyl
All spimplifed in 48
[Linked Image from i563.photobucket.com]
Bruce, hope you had a great 4th. My rebuttal: don't think so, only difference is the length. Pretty sure. [Linked Image from pic50.picturetrail.com] [Linked Image from pic50.picturetrail.com] Remember, their are two four door models.
Russell #38868
I have to agree with Russell, Bruce. The sales document you posted is of a Fleetmaster 4 door, not a Fleetline 4 door (note the rear quarter window....the Fleetline doesn't have one like that). And I would assume the panel trim on the Fleetline 4 door would be more in line with the Aero. Anyone have a photo of the interior door panel for a 4 door Fleetline?
Russell, does your 4 door fleetline door panel look like the pictures of my Aero door panels? (except for being shorter?)
ken48
VCCA 42589
Well if anyone has a fleetmaster I have pannel moulding for you
