Posts: 825 |
Hi there, I have seen on a 34 chev, the same as mine, chrome trim rings for the 17 inch wheels. I have searched the web and find that they are available on ebay for smaller wheels and also 18 in wheels. But not for 17 inch? does anyone know if they are still available for 17 inch chev wire wheels?
Peter
Posts: 3,469 Likes: 48
Posts: 3,469 Likes: 48 |
I looked for years for 17" trim rings for my '35 Standard. I finally saw a set of 6 on ebay that were described as 16' rings. I could tell from their appearance that they were not for '16 wheels so I contacted the seller and got some measurements. Based on the measurements, I decided they were 17" and bought them. They were NOS and genuine GM (GM was stamped into the tabs that hold them on the wheel) but I could not get them to go on my wheels. They were too large. I checked my '35 Accessory book and discovered that the rings for Master and Standard were different even though both series used 17" wheels. I was talking to a friend of mine who has a '36 Master. He said that he had bought a set of repop trim rings for his car but they would not stay on the wheel. We traded rings and solved our problem. I will call him and find out if he remembers where he bought the rings I have. The visual clue that identifys a trim ring larger than '16 is the notch for the valve stem. It is almost non existant on the 17' ring. It is just a barely noticable dip in the inside edge.
Posts: 1,869 |
I believe Bill Hirsch has trim rings for 17" wheels.
Posts: 396 |
Pat,
How can one contact Bill?
You can look him up on Google. He also advertises in the Generator & Distributor.
Posts: 409 |
first listing on Google, typed in (trim ring 17") and got this site I need a hubcap. com
Posts: 3,292 |
Interesting, but those are ABS chrome plated plastic
that site also offers stainless, but not in that size 17"
mike
Posts: 825 |
thank you all for your help. I fear that the quest will be ongoing for many years. Maybe I & I should start manufacturing them again? the filling station just buys off I&I and adds $10/$20. Hmmmmmmmmmmm Peter
never give 100% unless you are giving blood.
Posts: 3,292 |
I went thru the same searchs a while ago looking for 17 stainless trim rings.
I would think the best chance of getting them would be WHEEL VINTIQUES in california........but only if the demand was there for 17 " wheels with trim rings.
I also thought of buying 18" ones and making a welding jig and cutting one into 4 equal pieces until it was 17" and then TIG welding it together. The amount of work in making the welds seamless and polishing them, just doesn't make sense time wise.
Sooner or later somebody will do them, I can wait or do real nice triple pinstripping instead.
mike
Posts: 825 |
Hi there, Thats an interesting idea Mike, but so much work involved! Has anyone bought and fitted the chrome on acrylic rings mentioned earlier? Maybe they look OK? I have just sent that company a message asking about 17 inch rings and it will be interesting to see what they reply with.... Peter
Posts: 409 |
if you decide to make them DON'T use Al's metal spinning in New Castle, Ca. you will never get your parts or your $$ back.
Posts: 3,292 |
I believe Bill Hirsch has trim rings for 17" wheels. I googled bill hirsch and he shows 2 types for 17 inch wheels. mike lynch
Posts: 825 |
Hi there Mike, I did too, (google) and dont know which ones fit a 34 chev with 17 inch rims?
Peter
Posts: 3,292 |
Peter ==========================================================Does anybody know on this chat site have & they purchased the 17" trim rings from Bill Hirsch. Do they fit the 17" chev wheel correctly and if so which of the two is correct. I guess the other answer would be to contact thru email Bill Hirsch to correctly answer the question. When in doubt always ask the well respected seller. mike
Posts: 825 |
hi there, he has 17 inch rims, in wide and narrow fittings, but I have no way of knowing which would fit my wire wheels. At $60 per rim, I cannot afford to find out the hard way. Seems like I will just have to put them on my too hard to find list....... Peter
Posts: 3,292 |
I received an email this morning from BRETT HOUSTON of New Zealand. He has problems getting onto VCCA chat, but can read it online.
POSTED ON BEHALF OF BRETT.
Brett states......" I don't seem to have any luck getting onto the VCCA Forum, but just love reading it."
" I have just bought 17" trim rings for both my cars from Bill Hirsch. ( 35 EC standard sedan and 35 cabrio Holden Body----wheels for both cars are the same ) I got the small cut out rings as they are out of stock of the larger cut out rings."
" They fit my wheels just fine, but i had to enlarge the cut out for the valve stem by about 10MM. It did not take very long with a die grinder , but i am worried about rust in years to come." brett houston
No worry brett , if they are stainless steel , will never rust
mike lynch
If he will post a request with all the data an Elf will take care of it.
I think the point is that if he was able to post a request, he would not have a problem to be solved by said Elf.
Posts: 3,292 |
If he will post a request with all the data an Elf will take care of it.  RAY THE ELF if you care to contact Brett Houston direct, and help him with his problems logging on to CHAT here. he is .... brett at btsl.co.nz I believe brett owns either a 34 or a 35 standard touring mike lynch
Posts: 183 |
I have Bill Hirsh's stainless 17" trim rings on my 1935 Std coupe, and they fit perfectly! I bought them several years ago at Hershey and they really look great! I have put several thousand miles of driving on them and never had one come loose. A little chrome polish and they still glisten as new! As I recall, they were made in South America and imported here. My wire wheels are 17 inch, the tire size is 5:25/5:50x17. To be honest, I do not recall if they have the large or small valve stem cut-out, and I can not see them until I get the car out of winter storage, which may not be for 3 or 4 weeks. Phil Lipton millnphil@yahoo.com Let me know if there is any thing more I can do to help. Phil
flip
Posts: 1,869 |
I asked Hirsch the question and he says that for the '34 Chev Master, it is the ones with the small cutout.
Posts: 825 |
I contacted bill Hirch and I need the rims with the small cut out seems. I will order and post pics when they arrive and are fitted........... Peter
Posts: 825 |
hi there, today the 17 inch trim rings arrived, well packed and in good condition, But the cut-out is to small for my valve stems, its the small cut-out that I was advised that was correct for my car. Apparently NOT.
How do I grind down and ENLARGE these cut-outs ? the overall quality is superb and I dont want to compromise the finish....
Peter
Posts: 825 |
an update, emailed Bill Hursch and he replied that he thought that I had a Master. The standard and the Master use the same ring but the standard has the larger valve stem cut-out. I can either return them or find a machinist workshop that can grind them out to the right size. has anyone done that on this forum?
Peter
Have you tried them on a bare wheel with no valve stem in the hole to make sure they fit the wheel itself? Once you modify them, if they still don't fit your car, they are not returnable or useful to anyone else. Just a thought.
Posts: 3,292 |
Are these polished stainless steel or are they chrome plated ?
You can easily open up the valve area in the stainless steel because it will not rust.
Chromed would have to be silver painted with a hobby brush where the opening took place.
mike
Posts: 825 |
Hi there, they are steel with chrome plating. today I used my 4 inch angle grinder and a new wheel to enlarge the valve openings. I tried a Dremel type instrument, but the grinding wheel wore out in about 30 secs.
I had to be very careful with the grinder, its large and not very user friendly for small jobs and second it generated a lot of heat, causing bluing of the metal if one was not careful.
I did the initial grind and then finished using new round file and lots of patience. Ear muffs and safety goggles were a pre requisite and the noise if I removed the muffs was deafening.
The job is now done and the bare steel is painted with galv paint.
Peter
Posts: 3,292 |
Another job well done, quit congratulaling yourself and get on with the next one........!!!
LMAO
mike
Mike, Back off just a bit. He deserves to bask in the glory for a few minutes before getting back to another challenge. Walking the grinding wheel across the shiny chromed surface is easy to do with the tools used and he avoided that 'chuck hole'.
Posts: 3,292 |
It was luck , just luck, i think
mike
Posts: 825 |
Hi there Mike, thank you for your kind words........ I wrote the description of my honest attempts at doing the job in the hope that it would be of interest and Useful to other who may attempt the same exercise. I had no idea that the wheel could jump and cause the catastrophic damage that you and chipper were fully aware off? As you now say, I was extremely lucky to get away with what I did. I now hope that anyone else attempting this tricky operation will approach it with EXTREME caution and be aware of the pitfalls and accidents that MAY happen. Thank you all for you input.....the next challenge is that the tandem kit that came with the wiper motor will not fit in any way shape of form and I now have a battle to return it to the USA for a refund. My car will now only have one wiper it seems! Onward, Onward..............>  Peter
Posts: 183 |
I own a '35 Std and have a set of Bill Hirsch Trim rings bought several ago on the car, If you wish, i can measure the diameter of the valve stem hole and post it for you. The Master and Standard wheels are different, They use the same size tires and inner tubes so I have difficulty understanding why the valve stem hole would be different. The Master wheel has a larger opening for the hub cap, and has six mounting lug holes, the Standard wheel has only five Lug holes. Both use a 5:25/5:50/17 tire and tube. I will measure mine and send you dimensions tomorrow!
flip
Posts: 183 |
I went out to my '35 Std Coupe just now, and measured the diameter of the notch for the valve stem. The closest I could come without removing the trim ring was 3/4 inch. Mine fit perfectly. and have driven probably 2,000 miles without losing one! However, when I installed them I did bend the retaining tabs slightly to insure a snug fit on the wheel. Good luck with yours, and many happy miles!
flip
