Let me get this straight.
The CCA relates to the time you can grind on a battery before it's voltage is depleted. That about right?
The voltage of a 6-volt battery is 6-volts. That about right, too?
If your car's engine is in good shape why do you have to grind on and on to get it started?
I haven't bought another Optima for a long, long time. The first one I bought was a 12 volt and it was a piece of junk. Maybe they have improved.
I like my Interstate but if those Optima's will last three to four times longer - as the testimonials indicate, then maybe I should reconsider my stand.
Chipper, what say ye?
Charlie
BTW: Will the Optima keep the electric clock running longer.
I don't use no stinkin trickle charger, either.
