I haven't pulled one lately but it seems that I have merely backed up the support where it is attached by backing it up with a jack or real heavy hammer. This would be, of course, after taking out the cotter key and taking off the castle nut. Turn the nut upside down and tighten it just enough that the threads are flush at the top. Then take a lighter hammer and tap it with increasing force until it pops out. It is tapered in so it should come out without too much force. They usually do.
I don't think this is a better solution than a puller but will do the trick if you have enough room to work.
I don't like the fork method too much but don't know why. I guess because it may damage the dust cover of the tie rod end. But you are going to replace that anyway. Right. Go figure.
Good luck with it.
Charlie
BTW: The preferred method for garages nowadays on later model cars, when the customer is not within sight or within earshot, of course, is to take a big hammer and smack the side of the support at the tie rod. A couple hard knocks and they pop right out. Anybody ever seen that done or have done it?
