Posts: 49 |
How hard is it to set up the crownwheel and pinion after new bearings have been installed on the pinion shaft ?? I have a WSM is it as easy as it sounds ??
1935 Mst Roadster,1939 Norton Big 4 outfit, 1942 Buick, 1943 GPW,1959 Bel Air 2 Dr, 1963 Corvair Convert. 1956 FJ Holden Ute Hooroo from OZ
Hi Dave41, If you have the tools and the instruction book and have a knack for being a good chap at following instructions, it's not all that bad. I hope you kept all the shims that were installed at the factory and know where they were installed. If you get into trouble, come on back here for more instructions.
