#201187 03/18/11 08:34 PM
HerbK Offline OP
Any one know a person or company, hopefully on the East coast that is competent repairing Chevy speedometers? Last person that I sent it to had it the better part of 6 months, didn't do what I wanted (reset the main odometer to the mileage that showed when I sent it off) sent it back with the trip odometer not working (worked before) and reading about 15 MPH slow at 50 MPH (said that he had it "right on the money")-- was only about 5-6 MPH off when sent.
Herb Kephart
When I works,I works. When I stops to think,I goes to sleep
HerbK #201202 03/18/11 09:56 PM
Why not try doing it yourself?
I rebuilt 3 good out of 4 old ones.
Had never done before.
You can buy the refacing kit from the Filling Station for around $25 USD. The main thing is to clean all the gears, lubricate, and the calibration process is pretty simple.
Cheers
Ray
Calibrate at 1000 RPM showing 60MPH on the dial. There is a small brass lever that does the adjusting on the inside.
28 Chevy LO Capitol 1 ton, 28 National 2 dr coach, 71 Chevy Custom Camper 3/4 ton. Also 23 Oldsmobile Economy truck and a 24 Olds sport touring.
HerbK Offline OP
OK-Thanks
Guess that I'll give it a go
Herb Kephart
