Posts: 4,446 |
I removed the coil from the engine and now it seems the bracket won't seperate from the coil. Is it made onto the coil? When I try to pull it off it seems like it is made to the coil. This doesn't sound right. Before I get any tougher I thought I'd ask about it.
If its an original 1938 coil the bracket is permentally attached to the coil.
Posts: 4,446 |
Posts: 1,135 |
If its an original 1938 coil the bracket is permentally attached to the coil. This seems strange to me ??? On the coil on my 38 coupe, I think it's original, the bracket separates from the coil. The parts book lists them as separate items....COIL 1933 TO 1940 #186461 ALL.....COIL BRACKET 33 TO 40 #1871821 ALL Except COA. Am I missing something here???.. THANX ED
Posts: 241 |
ED 1938
The part # 186461 is the part # for a replacement coil. The replacements came as 2 unattached units in 1 package. The original coil from the factory had the mounting bracket spot welded to the coil body but all of the replacements were 2 piece. They show up on E-Bay now & then. Actually they came as 3 piece units you had to attach the cover that the Electrolock attached to also.
Sparky
Posts: 1,135 |
Sparky...Thanx for the info...Do you know the part # for the original factory coil assembly ????....THANX ED
Posts: 241 |
Sparky
